jingling tab on belt tensioner
Old Apr 12, 2010 | 07:32 AM
Scanner's Avatar
Scanner
has anyone had this jingling sound silenced on their belt tensioner ?...only hear it at idle...2005 MCSa
Old Apr 20, 2010 | 11:27 AM
Neufusion's Avatar
Neufusion
Determine if it is the s/c which is known to fail, or if it is the belt tensioner.
If it's the s/c, you may be able to remove it and drain/fill the oil, although it's a 6+ hour job.
If it's the belt tensioner, replace it.
Old Apr 23, 2010 | 03:18 PM
Scanner's Avatar
Scanner
sc sounds fine...it's the adjustment tab that sticks out of the tensioner vibrating at idle...just can't reach it with my hand...I heard that sometimes bending the tab works...not sure I want to risk that
Old Apr 23, 2010 | 06:22 PM
healey67's Avatar
healey67
get a long screw driver... push it between the spring and bend it.. otherwise spend some money and change it
Old Apr 24, 2010 | 11:47 AM
Scanner's Avatar
Scanner
thanks for your input...I will try the bend...otherwise it will have to get changed...
vulkandino
Oct 31, 2015 08:29 PM
VanisleRyan
Sep 30, 2015 08:35 PM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
daviday
Sep 25, 2015 01:31 AM
