Car cranks but doesnt start.
Old Apr 10, 2010 | 10:28 PM
Sandrei's Avatar
Sandrei
2005 MCS 45k Car ran fine just prior, battery seems fine, oil / gas everything is in order. Came out of the building dropped in, turned the car on, it went on for about 15 sec as if nothing was wrong then revs dropped and now it refuses to start. Engine is turning over fine so the starter is ok, tried to jump it, no luck, a push start didn't help ether. Would an acting up ECU produce this? I'm thinking ether that or fuel pump / plugs. It also threw battery light and engine oil, so I'm totally confused. Any help would be greatly appreciated.
Old Apr 14, 2010 | 01:19 PM
ortuna's Avatar
ortuna
New to minis but with other cars, I would go to the auto store and get quick start, which is a spray to the intake and it will give combustion while you try to start it. That way you can rule out plugs or fuel delivery.
Old Apr 14, 2010 | 01:32 PM
ZippyNH's Avatar
ZippyNH
Could be any one of a number of things...I would assume it has been towed by now....any updates?
Old Apr 14, 2010 | 02:21 PM
Sandrei's Avatar
Sandrei
Turned out to be a blown fuse, no power to fuel pump so that was sorted out. Also the spark plugs were very much the original that came with the car, all gummed up and dirty, changed those aswell / cleaned Ignition coils of rust. Car runs much better now, no stuttering, very smooth overall. It wasnt cheap ether, so no more mini/bmw dealership service for me for a while, DIY or Indy from now on.
New peoblem though, steering is considerably harder, not sure if its another fuse or just something that came as a result from a reset ECU.
Old Apr 14, 2010 | 04:30 PM
Sandrei's Avatar
Sandrei
Ok this is a very strange issue with steering now, it seems to be alright for 1/4 a wheel turn, but further you go the harder it gets, at 1/2 it lets go and is easy again, almost feels that they have bent something while getting it in to the garage.
Old Apr 14, 2010 | 04:54 PM
ZippyNH's Avatar
ZippyNH
How does it feel when you are parked, and turn the wheel?
Many gen1 mini's need ps pumps at some point.....do you still hear the humm of the pump?
Old Apr 14, 2010 | 05:03 PM
Sandrei's Avatar
Sandrei
Thanks for a quick answer! Yes the pump works, I can hear it going at it, but I have not had any issues with it up untill the car got stalled. It feels as if something is bent, and steering wheel rotates very uneven, from normal to stiff and back.
Old Apr 14, 2010 | 05:25 PM
ZippyNH's Avatar
ZippyNH
Was the car towed with a flat-bed?
When it was winched up, did you attatch the towhook that comes with the car or did the driver just hook onto something under the car?
The corrosion on the number 3 coil terminal is very common...I replaced mine with a MSD that has brass terminals for this reason...cost about $90. The terminal can be polished once or twice...but it is just nckel plated steel...so it quickly turns into a loosing battle. A drop of electrical grease might help slow down the corrosion.
The blown fuel pump fuse is very odd...keep that in mind...the pump maybe on the wayout, or maybe you got some fuel with some grit that jammed the pump or something....
The mini standard for changing sparkplugs is way to long for a performance car......IMO they should he swapped out at maybe 30,000 miles or so...especially if the car has a reduction pulley on the supercharger...
I would check the ps fluid level...and if low, add the correct special fluid, petrosin...mini, VW, and BMW sells it.
Old Apr 14, 2010 | 05:41 PM
Sandrei's Avatar
Sandrei
It was a flatbed, didnt find a hook ( didnt know I needed one, got one at mini after the fix ). Guy hooked it up to the rear axle under the car.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Toolman
Jan 20, 2016 06:50 AM
TunedGP
Oct 1, 2015 04:18 PM
Lt. Dan
Aug 10, 2015 12:46 PM
