Is replacing an axle half shaft and wishbone a DIY project?
Old Apr 3, 2010 | 04:10 PM
DeusRx's Avatar
DeusRx
Hello All, my R53 was slammed sideways into a curb. The wishbone (control arm) was bent and the half shaft of the axle was pulled in half exposing the middle knuckle bearing joint. Is this a fix that I can do with just basic auto repair knowledge(brakes, oil and filters, etc..)? Does the Bentley manual cover this procedure?
Old Apr 4, 2010 | 07:16 AM
DaveVT02S's Avatar
DaveVT02S
Yes, though it is a little more than a brake job - a small-size ball joint splitter will come in handy, as well as 10, 13, 16, 17, and 22mm wrenches and sockets, and a torque wrench, and a certain degree of patience. The Haynes Guide has good instructions, so I would presume the Bentley does also.
A fellow owner got an axle at a chain auto parts, the LCA will take a little digging -
Good luck
Old Apr 4, 2010 | 08:48 AM
Aeromax's Avatar
Aeromax
I believe you'd have to drop the subframe, but the experts could tell you better. Not sure how else you'd get the control arm out of the stock bushing. They're in there really tight. I just dropped the subframe for the first time last week, and it was pretty easy to get off the car. Getting it back on was a little harder, but nothing that I couldn't easily do now that I know how. I was working alone too, only with jackstands. You should look into replacing your control arm bushings and ball joints at this time, if your car is older.
eliseo1981
Jan 28, 2021 02:45 PM
blackie
Jan 18, 2017 09:56 PM
FLYM1N1
Mar 7, 2016 05:41 PM
thebordella
Aug 31, 2015 01:37 PM
O4mcs
Aug 10, 2015 10:22 PM
