Bearing noise/whine
Old Mar 30, 2010 | 11:42 PM
ThisFlynn's Avatar
ThisFlynn
Bearing noise/whine
'04 MCS
Have a good deal of bearing noise from the water pump/supercharger area (i think).
The noise is definitely from that side of the engine and increases in pitch with the revving of the engine.
Any help with diagnostics or repair would be much appreciated.
I'm thinking this may be beyond my abilities to fully repair (though I have replaced the clutch on my own) so if anyone knows somewhere in the Monterey Bay area please let me know!
Old Mar 31, 2010 | 01:33 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Where is the noise coming from, passenger or drivers side of the motor ?
Old Mar 31, 2010 | 01:34 AM
ThisFlynn's Avatar
ThisFlynn
passenger side - right there at the serpentine belt
Old Mar 31, 2010 | 01:50 AM
-=gRaY rAvEn=-
Moderator
Mmm, well good news is that the waterpump is on the opposite side.
I had a similar issue, sounded like metal clanking, but it turned out to be the belt. Even though it was just 6 months old it was glazed over.
I would also check the bushings for your belt tensioner, and the harmonic balancer ( crank pulley ). The ones we have were natorious for separating and when they do, it can make some racket. I replaced mine with the 05/06 updated version. It is about 3 lbs lighter too
btw: If you were able to replace your own MINI clutch, you can practically do any other repair as well. Nice work.
Old Mar 31, 2010 | 02:11 AM
ThisFlynn's Avatar
ThisFlynn
I thought the water pump was tied in through the supercharger bearing
My father's initial diagnosis is that the bearing was wearing out - not exactly sure what that means/entails.
It's not really a clank - just a mid range hum/whine. Almost sounds like the electric whir of the steering but quite a bit louder.
Old Mar 31, 2010 | 02:24 AM
-=gRaY rAvEn=-
Moderator
I made a youtube sound of mine. http://www.youtube.com/watch?v=OUMCkeDSsqs
I would have sworn it was a bearing on the pully side of the SC. Just turned out to be a glazed belt.....
SC gears on the DR side powers the waterpump. Normally that is the side which fails.
Old Mar 31, 2010 | 02:34 AM
ThisFlynn's Avatar
ThisFlynn
I'll see if I can make a video of it in the morning.
Old Mar 31, 2010 | 02:40 AM
-=gRaY rAvEn=-
Moderator
QuickCooper
Dec 29, 2016 06:46 PM
vulkandino
Oct 31, 2015 08:29 PM
unxpectederror
Oct 22, 2015 12:16 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Nicefeet
Sep 24, 2015 06:53 PM
