Cold start rattle question
Old Mar 30, 2010 | 09:49 AM
Cole9953's Avatar
Cole9953
So is this something they all do or something that needs to be adressed?
And what is the cause?
Thanks in advenced for your respons
Cole
Old Mar 30, 2010 | 10:12 AM
ZippyNH's Avatar
ZippyNH
The widely discussed cold start rattle on this board is a gen2 (TURBO) car issue....Had to do with variation of length of the timing chain...there is a fix!!
If you have it on a gen1 car...then you need to get it looked at! It is likely something that should be fixed.....but more info, and description would be needed on a gen1 car.
Old Mar 30, 2010 | 10:55 AM
Tmini08's Avatar
Tmini08
I have never heard of generation1 cars having this problem, only generation 2 cars.
Old Mar 30, 2010 | 01:59 PM
Cole9953's Avatar
Cole9953
its a 06 cooper S, and i get a rattle sound for about 3 or 4 seconds upon a completely cold start. but once it stops no other strange sounds can be heard as far as i know( i have never been near another R53 that was running)
Old Mar 30, 2010 | 03:32 PM
ZippyNH's Avatar
ZippyNH
Does it sound like rattling chains??
Or more of a ping-ing?
Maybe the oil is just draining back to the lower end...causing a bit of rattle till oil preasure builds...do you have the guage package so you can see the oil preasure at start-up?
A cold rattle on start-up on a r53 is unusual...but it can happen...heck, just different reasons than a gen2 car.
Old Mar 30, 2010 | 04:41 PM
Cole9953's Avatar
Cole9953
It's not pinging, and the rattling chains seems like it would be too high pitched for what im hearing. I'd say it's a low/deep rattle. i dont have any gauges, to check but your oil pressure theory sounds good.
Old Mar 30, 2010 | 05:00 PM
ZippyNH's Avatar
ZippyNH
What are you using for oil? Oem or good filter like a Mann/mahle?
And good gas right?
Old Mar 31, 2010 | 09:40 AM
Cole9953's Avatar
Cole9953
Good gas and mobil one syn. I think my filter was a wix
Old Mar 31, 2010 | 11:03 AM
ZippyNH's Avatar
ZippyNH
Heck...sounds like maybe it just takes a few seconds for your car to wake-up in the AM. I'm surprised nobody has chimed in...but if it runs ok...I would not worry...maybe if it is under warrenty, mention it to the dealer...maybe even a compression check if you want to br crazy safe....but if it runs fine....and is not hurting anything....could be called just one of those things I guess.
Old Mar 31, 2010 | 11:12 AM
MiniCobra's Avatar
MiniCobra
Mine had that and it turned out to be the lifters had plastic tips that had deteriorated at 80k miles. The replacement cost me almost 700 parts and labor and were replaced with the new ones with metal ends. I have seen similar posting about this on other forums for the gen 1 minis.
Old Mar 31, 2010 | 01:44 PM
traction's Avatar
traction
on startup mine will taptaptaptap for right as the cars does its startup rev. then it stops. This is typically when it is cold out side.
Old Mar 31, 2010 | 03:52 PM
Cole9953's Avatar
Cole9953
sounds like we have the same thing going on.
well i hope the lifters aren't worn out because i'm out of warrenty, and im only at 32k miles.
Old Mar 31, 2010 | 04:16 PM
traction's Avatar
traction
im at 35k.....
Old Dec 28, 2011 | 06:05 PM
Mtnmotor's Avatar
Mtnmotor
rattle
My 2006 MCS w/36k Has this rattle when cold and car has set for a couple days. What fix did you come up with?
Old Dec 30, 2011 | 05:39 AM
AllPepperS's Avatar
AllPepperS
I just bought a 06MCSa with 45,600k on it and I drove it every day, every chance I got and never heard this noise. I took it to 3 different shops to be vetted before I bought it and it checked out well. The one place turned it on and listened to it for a good 10 minutes while they also checked the body and interior. Said it was doing everything right. I take it to work , 50miles, park it in the garage for 3 days and when I started it up I heard a bit of a noise like you describe. It drove home great like it should. I really like the car, is this a Mini ism or something I should be concerned about? I will see if it does it today after not sitting. It has good gas in it and good oil in it.
Tracy
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
iclancy82
Aug 11, 2015 09:35 AM
