Factory tires need replacing at 14k?
Old Mar 30, 2010 | 09:08 AM
Chimera's Avatar
Chimera
Just took my car in for the 1 year low mileage oil change, and they say that the front tires are at the wear bars. The tires have been rotated once, so these have only been on the front for about 8k. Is it normal that they need replacing after 14k miles?? The wear seems pretty even across the tire so I don't think it's a problem of taking corners too fast, and I really don't burn rubber away from lights etc (much). I didn't really want to buy 2 new runflats this week Inspection is due at the end of April, so I'll have to replace them soon....
Old Mar 30, 2010 | 09:23 AM
MattSaint's Avatar
MattSaint
Curious, are these summer run-flats? What is the treadwear rating? If it is 280 or so, they could very well need replacing at 14k.
Old Mar 30, 2010 | 09:59 AM
Chimera's Avatar
Chimera
They're the stock Conti 16" all-season RFs. Looks like 2 new ones are $144 each from Tire Rack.
Old Mar 30, 2010 | 10:48 AM
Tmini08's Avatar
Tmini08
Ditch the run flats, and you will not regret it.
Old Mar 30, 2010 | 11:10 AM
Chimera's Avatar
Chimera
I've thought about it, but that would mean buying 4 new tires instead of 2 right now, and I'd have to deal with either keeping a donut in the car. I don't like the idea of just relying on Slime to get me home. I really don't mind the ride with runflats, so ditching them would really just be a cost saving more than anything.
Old Mar 30, 2010 | 12:43 PM
quikmni's Avatar
quikmni
For the two Minis I had, I wore out the stock RF tires around 15K.
Old Mar 30, 2010 | 05:25 PM
manish's Avatar
manish
I'm at 19K with th 16" contis and they are not really that worn, but just bad tires. They really had poor grip this past winter in even light snow. Plus I had a bad experience with the runflats and a pot hole. The sidewall is so hard that it cracked my rim and busted my headlight from the impact.
I didnt want to replace them until the tires were worn out, but they already cost me a $1000 lesson. Im replacing them ASAP with nonrunflats. now if I could only figure out what.
Old Mar 30, 2010 | 07:12 PM
moodylewdd's Avatar
moodylewdd
My car came with Pirelli runflats...the fronts lasted 20,000 miles (even with rotations). They wanted 260.00 a piece for them, so instead of spending over 500.00 on two tires, I bought a whole set of non runflats for almost the same amount. Much better ride, and if you drive on a flat runflat you'll have to replace the tire anyway.
I have a slime kit (you can get from Wal-mart) for right around 20.00, and it includes an air compressor. Dont think I would go back to the original set up for anything.
Old Mar 30, 2010 | 08:41 PM
rdwatt's Avatar
rdwatt
My stock Conti 16" all-season RFs have 27,350 miles on them with some tread left. What kind of mileage are the rest of you getting on your stock tires?
Old Mar 31, 2010 | 06:31 AM
jcauseyfd's Avatar
jcauseyfd
I got 40k out of my stock Goodyears.
Old Mar 31, 2010 | 06:52 AM
MINImalistnam's Avatar
MINImalistnam
Rdwatt, my tires are the same as yours and I expect them to last about the same as yours. Thinking hard about non-runflats and a Slime kit. A classic MINI debate !
Old Mar 31, 2010 | 10:52 AM
rdwatt's Avatar
rdwatt
There's no way I'll get that out of mine. I might be able to get 30k.
Old Mar 31, 2010 | 11:26 AM
Herleman's Avatar
Herleman
Just measured my stock Bridgestones at 7K. They're about 40% worn. I estimate 20K. I'm rotating them at 3K intervals and they are wearing flat and even, but they are wearing fast in my book. They indicate Treadwear 320, Traction A. I have no real problem with the tires except that they ride very harshly and they hum loudly and incessantly on the highway. I've found those traits to be common on all but the highline Pirelli RFs. I've not really found a problem with handling, but I seldom push my Justa to the limit anyway. Mine has a donut AND the RFs so I can change to non-RFs with no penalty. I'm debating whether to stick with the stock 195X55X16 or go to 205X50s, or perhaps even 215X55s. I'm leaning toward staying with the stock size right now because I feel like the added sidewall height will provide some protection for the rims on rough mountain roads, and the narrower tread footprint will help in fuel mileage (and let's face it, I can seldom use the full potential of even the 195s in an automatic justa so additional tread width or lower aspect ratio has little value for my needs except for the improved "looks").
Colt45Magnus
Aug 12, 2015 06:43 AM
tippin
Aug 5, 2015 08:43 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
