R50/53 Flushing block and head of coolant
I'm finishing up replacing my head and was curious as to a way to flush the coolant passages out. I used a Scotchbrite pad to clean the deck surface and while I did block off the oil passages, I didn't with the coolant. I want to flush out as many of the micro-particles as possible, along with any gasket material.
Tell me if this would work:
Put on the head, torque it down, then with the t-stat housing off, pour water from a hose through that port, let it run through the head and block and out the waterpump port on the block.
The old-school method is to drain the radiator, then fill the system with cold water and run the engine just until it boils. Let it cool and repeat 2-3 times. Then do one last drain. Find out how much antifreeze the engine block itself holds. Add and equivalent amount of pure antifreeze to the radiator, then top it off with 50/50 mix. I definitely recommend only using BMW's brand, which has that dark turquoise color. It's $20/gallon, but remember one makes two when mixed 50/50.
COOPT UP
Sep 11, 2015 04:59 AM
Sep 2, 2015 09:05 AM
