R50/53 Flushing block and head of coolant
Old Mar 29, 2010 | 01:33 PM
plasticknives's Avatar
plasticknives
I'm finishing up replacing my head and was curious as to a way to flush the coolant passages out. I used a Scotchbrite pad to clean the deck surface and while I did block off the oil passages, I didn't with the coolant. I want to flush out as many of the micro-particles as possible, along with any gasket material.
Tell me if this would work:
Put on the head, torque it down, then with the t-stat housing off, pour water from a hose through that port, let it run through the head and block and out the waterpump port on the block.
Old Mar 30, 2010 | 09:15 AM
JumpingJackFlash's Avatar
JumpingJackFlash
The old-school method is to drain the radiator, then fill the system with cold water and run the engine just until it boils. Let it cool and repeat 2-3 times. Then do one last drain. Find out how much antifreeze the engine block itself holds. Add and equivalent amount of pure antifreeze to the radiator, then top it off with 50/50 mix. I definitely recommend only using BMW's brand, which has that dark turquoise color. It's $20/gallon, but remember one makes two when mixed 50/50.
Old Mar 30, 2010 | 09:22 AM
plasticknives
The thing is I want to flush out the head and block before attaching the radiator/water pump/etc. I don't want to grit from the Scotchbrite to touch those and cause potential wear.
Old Mar 30, 2010 | 12:01 PM
JumpingJackFlash
That's a tough one. You would have to look for some kind of drain plug on the block itself and open it up. Then pour water through each of the jacket holes from top so it flushes downward.
Old Mar 31, 2010 | 11:41 AM
plasticknives
I ended up plugging the water pump port with a piece from a toilet and used a hose to fill the block with hot water through one of the jackets. I then used a shop-vac to suck it all out. Did that process a few times. I also sprayed the headbolt holes with brake cleaner and sucked it all up. Worked very well.
Old Mar 31, 2010 | 11:45 AM
Dr Obnxs's Avatar
Dr Obnxs
Now that's engineering I like!
effective and cheap. It sucks that there is no good drain for the block.
Matt
jef1f
Sep 18, 2015 02:49 PM
COOPT UP
Sep 11, 2015 04:59 AM
Manny_cooper
Sep 4, 2015 08:28 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 09:05 AM
