Suspension camber plates help??
I bought a set of Ireland engineering camber plates and i can see that everything is straight forward except that i don't know which camber palte goes to the left and which goes to the right.
thanks in advance.
Carlos.
thanks in advance.
Carlos.
Look at the bolt pattern on top of your strut towers, You'll notice that they match the plates. The Camber bearing is then offset towad the center of the car.
If you look at the stock camber bearing (you can see it through the hole in the top of the strut tower) you will notice it is aligned with the hole. The IE plates will, again, offset it toward the center of the car.
what is the correct alignment!!!
Hi all,
I installed a set of irland engineering support plates to avoid the mushroom problem but I need to know the best set up for alignment( This is my driving style:80 % straight (Monday to Friday) & roads 20% curves (Weekends).
Also,
I notice that the driver side hits the inside wall,
anyway knows how to correct this?
thanks in advance.
Also,
thanks in advance.
Several threads combined into one, and all moved to the proper forum.
Please do not cross-post! Simply place your thread in the proper place and it will get answers.
From Site Guidelines:
SEARCH
Before posting, use the Search function to see if there has already been a thread on the same subject. Do not start identical threads or cross-post the same thread in different forums.
Interior/Exterior Chrome strip above license plate, who makes black ?
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
