Couple of questions about 04 S
1. My passengers side front wheel is hopping around slightly under most driving conditions(cornering), and severely when hammering the corners. Bushing, shock, anyone have this issue and know the fix? It doesn't happen on driver's side.
2. When running A/C or heater, the fan is making a loud noise. I notice it when sitting at stop lights. Replace the entire fan? This is my first mini and these cars seem to have many electrical issues, so I figured id ask for help.
THX
This car is a 6 speed w 73K miles.
THX
Sounds like the control arm bushings may be bad. Mileage is about right; mine went bad around 80K on my old '02 MCS. Bavarian Auto sells new ones for $57.95 each. Or you could upgrade them to Alta solid casters (which are pressed into the bushing housing). They run about $230, but they will never go bad again.
Also check the ball joints in the control arms. In rare cases, the rubber seal could be busted and grease has leaked out. Bavarian Auto has inner ball joints for $97.95 each, and the outer ones are $79.95 each.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
Jan 30, 2021 01:35 AM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
TunedGP
Oct 1, 2015 04:18 PM
R50/53 R53 Chrono Pack - gauge?
missinmyjeep
Aug 22, 2015 07:13 PM
