synchros
Old Feb 23, 2010 | 10:20 AM
GregO's Avatar
GregO
synchros
2006 MCS 29,000 miles. Original owner. Car is wife's daily driver. I occasionally drive it and notice 2nd, 3rd, and 5th gears are unusually notchy to me, with 5th and mostly 2nd being the most annoying. While it's not grinding, going into 2nd feels like it's "catching" or getting hung up briefly before the "gate" opens. Seems more pronounced with more spirited driving. Any way to test this to evaluate if it might be the synchros or something else. Might be time for a warranty visit, but would like to be sure if at all possible. Hoping not to hear it's one of MINI's charms/quirks.
Thanks!
Greg
Old Feb 23, 2010 | 10:22 AM
markjenn's Avatar
markjenn
I'd change fluid and hope for the best. Might be difficult to get any warranty consideration just for notchy shifts - box might have to be broken.
Shifting too quickly is the usual culprit for wearing out synchros. If your technique is poor and you regularly jam it into the next gear before allowing the synchros to do their job and match gear speeds, you'll wear them out, sure as shinola and then the grinding begins. Smooth, deliberate, unforced, and unhurried shifts are the key to keeping a box in good shape. Second gear (noticeable on the 3rd to 2nd downshift) is usually the worst. And do you or your wife regulary downshift through the gears when coming to a stop? This adds a lot of extra wear/tear on the whole drivetrain. On a normal decel to a full stop, best to leave it in whatever gear it is in and do all your downshifting after the stop. The only way to fix it is to rebuild the box.
Good luck!
- Mark
Old Feb 23, 2010 | 11:08 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I think that the syncros still cannot be obtained individually for the Getrag. If one is dead, it's a new transmission for you.
Old Feb 23, 2010 | 01:03 PM
GregO's Avatar
GregO
synchros
Good luck!
- Mark
Given that this car never sees redline (or anywhere close) with my wife's leisurely driving habits, I'd have to dismiss any notion of naturally wearing out the synchros prematurely. Bad tranny/design/engineering/batch I'd believe, but since this car is well looked after (except those times I drive it ), I expect I'll be asking the dealer to take a look before too long since we're good on warranty until October 2010. My gut says synchros with the odd stumble/studder into 2nd, but I honestly don't know.
Greg
Old Feb 23, 2010 | 01:26 PM
Crashton's Avatar
Crashton
Just throwing this out there before you search for syncros.
As has been said, change out the fluid. If there is still an issue shifting look at the shift cables. Clutch release working? Lots of easy stuff to check before doing a syncroectomy.
Good luck & let us know what you find.
Edit.... You are under warranty , then get it in the shop.
Old Feb 23, 2010 | 01:40 PM
ZippyNH's Avatar
ZippyNH
have you looked at the linkages yet? They could be covered in grime/road grit....or they could be out of adjustment. i would have it looked at by someone who know a MINI before I would get all worried it was a synchro that was going out.....Manual transmissions tend to be pretty reliable unless beat on....I'd eliminate the simple stuff first since you said your wife is not a performance driver....
I would NOT continue to put lots of miles on the car, and do lots of shift while wait to get it trouble shot, as you are likely causing damage to the syncros due to not getting positive shifts.....I know our MINI guy said he has started to lube and clean the linkages on the transmissions...the were getting covered in grit sand, and people were amazed at how much better their cars were shifting when they were cleaned and lubed.....Yours might need an adjustment too like I was saying....
Good Luck!!!
Old Feb 23, 2010 | 06:35 PM
GregO's Avatar
GregO
synchros
Thanks for the posts! I'll try the basic maintenance adjustment items first and go from there.
Greg
Old Feb 25, 2010 | 10:15 PM
Mini_Crazy's Avatar
Mini_Crazy
Try MTL. . .
Greg
When you are changing fluid in the trans, consider replacing it with Redline's MTL Many folks have found that it shifts smoother than stock (new) fluid, and it does meet MINI's specs. It also works with the LSD (limited-slip differential) if you have one. You will need 2 quarts.
I have even had a service tech comment (without any prompting) on how smooth my car shifts.
Old Feb 26, 2010 | 12:06 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Redline makes good stuff. I use MTL in my MINI. Shifting was notably better when I first switched. I'm able to buy it locally from Speedway Motors.
Old Feb 26, 2010 | 05:36 AM
thulchatt's Avatar
thulchatt
If it is still under warranty get it in just to log the issue. You may not get anything changed but if it is a real problem you want MINI to have it in their system before the warranty ends. This might get you more consideration if you need a new trans after the warranty.
Then change the fluid and do the maint others have recommended.
Old Mar 1, 2020 | 06:43 AM
booyah93's Avatar
booyah93
Whatever happened to this?
What all should I check before assuming synchros?
My car will grind 50% of the time when putting it into reverse. All other time it slams in and sounds bad. Lately I've has trouble getting into second an third gear, and first gear with my foot pressing the clutch was causing my engine to idle very rough. I replaced with 75w-80 GL5 gear oil. All the lable was in German, but I bought the redline last night and today is my last day of work. Tomorrow I'll put in syncromesh to flush out the GL5
Old Mar 1, 2020 | 06:46 AM
Fly'n Brick's Avatar
Fly'n Brick
TO bearing.
Old Mar 1, 2020 | 06:54 AM
booyah93's Avatar
booyah93
Originally Posted by Fly'n Brick
TO bearing.
Fast reply ty.
Hey I'm sick of doing these massive repairs my self, so how much would certified transmission charge me to replace it? Should I just do it my self?
Old Mar 1, 2020 | 01:21 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Depends on shop that does not think double the cost when they see you pull up with a Mini. Prob around 1200 to 1500. Or just do it your self. Go to mod mini site an watch his clutch swap video.
Old Mar 1, 2020 | 02:25 PM
booyah93's Avatar
booyah93
A guy at my job says check the fluid levels for the slave cylinder otherwise it sounds like a clutch issue. I suspect the old owner didn't change the throw out bearing.
Way suggests OEM $250 however other threads suggest Valeo or Luk ~$110 on Rock Auto.
I don't hear noises when the clutch is depressed and that's what Google says 1000 times what I'll hear if that's the problem.
Is there any input on which to buy? I'll be doing this my self, because there's no way I'll pay that much for a job like this. Thank you.
Old Mar 1, 2020 | 07:50 PM
booyah93's Avatar
booyah93
So the gears are shifting very smoothly now, but the car shudders while engaging the clutch especially from a dead stop in first gear or reverse.
zx9rider
Mar 1, 2020 07:51 PM
brockf56
14
Jun 14, 2016 11:40 AM
Andrew Riley
11
Jan 29, 2016 03:12 PM
Fr33zy
Aug 28, 2009 05:47 AM
ehdavis
Classic Mini Talk
23
May 28, 2008 11:00 AM
