Boot won't open - how do I fix it myself?
Old Feb 17, 2010 | 03:41 PM
Tom2112's Avatar
Tom2112
OK, I've read a few threads about boots that won't open. I know you can lift the rear seat and pull the release and it will open. But that is getting old. My car is out of warranty and I don't want to take it to the dealer - they charge an arm and a leg AND they're 80 miles away and I'd have to take time off work. So it's a double losing proposition monetarily.
So... has anyone repaired this somewhat common problem themselves? Have any instructions? Anyone have details or pics on how to get at the boot release mechanism and at least have a look?
Old Feb 17, 2010 | 04:10 PM
bean's Avatar
bean
I haven't had to repair one, but I have the release mechanism available if you need a new/used one.
Old Feb 17, 2010 | 05:00 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
My problem was the trunk wouldn't close. I had to replace the latch assembly. The solenoid was bad.
Old Feb 17, 2010 | 05:24 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Would also ck the wiring harness back there too. Member of our club had bad/frayed wiring found only after checking all other components.
Old Feb 17, 2010 | 05:39 PM
MLPearson79's Avatar
MLPearson79
There have been electrical issues there. Try the remedy in this thread:
Hatch goes "Boonk" all by itself! (FIXED!)
Definitely a cheap/easy fix if it works.
Old Feb 17, 2010 | 06:59 PM
Tom2112's Avatar
Tom2112
Thanks! The Bonk problem sounds like mine. It only bonked once, then wouldn't open at all. I will disassemble it and see what I find.
Old Feb 17, 2010 | 07:00 PM
Tom2112's Avatar
Tom2112
Double thanks! If I need one I will contact you.
Man I love car clubs. The people are always willing to help and share.
Old Mar 3, 2010 | 05:56 AM
Tom2112's Avatar
Tom2112
Well, I didn't go as all out as the Bonk thread poster did, but I did remove the boot trim and cleaned the corrosion and water leakage damage off the electronics of the boot latch. I sprayed the crap out of it with contact cleaner as well.
When I put the boot latch assembly back on the boot, I tightened it down nice and tight. Hopefully the stock foam rubber will make a good seal this time. I've been driving it for about 2 weeks and haven't had any more trouble with it.
I am still leery of it failing again and washing my car makes me nervous.
Old Mar 4, 2010 | 08:10 AM
bean's Avatar
bean
sevin
May 2, 2026 06:11 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
Aug 27, 2015 12:25 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
speedbird_1
Aug 15, 2015 04:44 PM
