Suspension Replace ball joints with control arm bushings?
Old Feb 11, 2010 | 09:14 PM
Neufusion's Avatar
Neufusion
At 85k my car is handling erratically and feeling really jumpy when moving throttle back and forth between 0% and 15%. Turns out the control arm bushings are shot.
I want better quality and stiffer bushings if I'm going through all the work to replace them so I'm going to go with Powerflex bushings.
I am considering doing the ball joints at the same time but I'm wondering what their life expectancy is and if it is worth it to replace them.
I can get the bushings for $90
or
Kit for $299 that includes:
1 set front powerflex control arm bushings
2 outer ball joints
1 Left inner ball joint
1 Right inner ball joint
How much more work/labor is involved to do the ball joints as well?
Old Feb 11, 2010 | 09:53 PM
tazio's Avatar
tazio
I just did my second set of CA bushings at 110k and original ball joints were still in good shape. You will love the PF CA bushings.
Old Feb 11, 2010 | 09:55 PM
tazio's Avatar
tazio
Oh, and make sure you check the lower engine mount. They are super cheap to replace and if yours has failed that could explain the "jumpy" feeling you describe.
Old Feb 11, 2010 | 10:08 PM
Neufusion's Avatar
Neufusion
Yeah my upper motor mount is bad and I've read that can kill the lower one too.
I think I'm going to try out these new BSH lower engine mounts:
BSH R53 Lower Engine Mount
http://www.bshspeedshop.com/store/home.php?cat=1141
Old Feb 11, 2010 | 11:07 PM
MNCRYSS's Avatar
MNCRYSS
124,000mi. and just replaced my LCA bushings with the powerflex and my ball joints were fine. WOW, the car is new again after the bushings were installed. My VIP engine mount's bushings are going so they're next on the list. I also just ordered BSH's lower engine mount too. FUN!
Old Feb 12, 2010 | 10:35 AM
Galactor's Avatar
Galactor
Are these similar to the TSW ones? If I remember correctly, TSW had a modified lower-one, but also sell the OEM upper one as a package since that one normally will go bad too.
I was wondering how long the ball joints lasted. My car has ~23k miles and the CA bushings are bad (previous owner ), so I was thinking of replacing the ball joints together. Based on the feedback in this thread, I guess the ball joints can wait.
Old Feb 12, 2010 | 10:57 AM
Neufusion's Avatar
Neufusion
Other way around... TSW has a modified upper one and sells the OEM lower one. The TSW upper mount actually doesn't apply to my car because it was built 10/2003 and uses a full rubber mount (like the TSW mount) instead of those leaky metal ones.
http://www.txwerks.com/servlet/Categ...%3AMotor+Mount
Old Feb 12, 2010 | 03:28 PM
Bigshot's Avatar
Bigshot
Don't confuse the engine mount (rubber ball/fliud filled orb) with the engine bushings.
The bushings try to hold the engine still while the mount simply supports the engine weight.
Old Feb 12, 2010 | 05:19 PM
Partsman's Avatar
Partsman
Legion_of_Doom
With your car at 85k, why would you have it all apart to do the bushings and not change the ball joints?
I did all my ball joints when I did my bushings...there was no way I was going to have the subframe laying on the floor and not do the ball joints while I had the control arms off.
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
