OBDII Reader will not Link to 08 Mini
Old Feb 4, 2010 | 06:42 AM
BigglesTAP's Avatar
BigglesTAP
After a recent engine code appeared I connected my Innova 3100 OBDII code reader which I've have for a few years to my wifes 08 Mini Cooper S.
Unfortunately now matter how much I tried it would not link and kept coming up with Error.. It works on other vehicles..
Having emailed Innova i have no relpy.
Any idea's??
Old Feb 4, 2010 | 08:53 PM
kukaepe's Avatar
kukaepe
Did you have the ignition on but the engine not running when you were reading the codes? I've got an Innova 3100 and it will not read the codes unless the "key" is in the running or on position. Worth a try...
Old Feb 5, 2010 | 05:09 AM
BigglesTAP's Avatar
BigglesTAP
Emmm pretty sure I did but I'll try again thanks...
Old Feb 5, 2010 | 05:11 AM
Helix13mini's Avatar
Helix13mini
sometimes you have to jiggle the connector into the car. It'll seem like it's connected, but actually you don't have continuity. Also, check that your ignition is in position 2, with your service engine soon light on.
Old Feb 20, 2010 | 09:44 AM
Stonetiger's Avatar
Stonetiger
have you tried updateing the firmware in the obd?
Old Feb 20, 2010 | 10:11 AM
cmcveay's Avatar
cmcveay
I don't have the model number on mine but it does the same thing and I have to actually start the car if I want to clear the codes. If I try to erase them with the car off, I get the "NO LINK" and an error. Start it up, it links, reads and I can delete without a problem. Good luck!
Old Feb 20, 2010 | 01:20 PM
BigglesTAP's Avatar
BigglesTAP
It was not possible on that model. Anyway problem solved sold it on Ebay.
I'll get another with the CAN now..
ClayTaylorNC
Aug 10, 2015 09:19 PM
kvnadriano
Aug 10, 2015 08:48 AM
iwantacooper
Aug 7, 2015 05:01 AM
mini pooper
RSR Motorsports Coverage
Aug 5, 2015 02:56 PM
