Navigation & Audio Aux Input not recognized problem
Old Feb 1, 2010 | 06:31 PM
dcarrier's Avatar
dcarrier
I've tried everything I can think of without having to pull out the head unit to get my new Auxiliary Cable to work. I plugged it in to the back of the unit, turned on my iPod and my HU will not change to AUX. Only between CD and radio. Im stumped and I don't know what to do next with this. Has anyone else had this problem? I've searched the forum here and have not been able to find anything. Any help would be greatly appreciated. Thanks
Old Feb 1, 2010 | 06:42 PM
ZippyNH's Avatar
ZippyNH
What year is the car...some of the earlier head units did not support all features.
Old Feb 1, 2010 | 06:44 PM
dcarrier's Avatar
dcarrier
Its a 2004 MCS with the Harmon Kardon speakers and such.
Old Feb 1, 2010 | 06:46 PM
ZippyNH's Avatar
ZippyNH
Should not be related to production date then...I think the first couple years externally looked the same, but omitted some features.
Old Feb 1, 2010 | 06:50 PM
dcarrier's Avatar
dcarrier
I've read about people with 03 and newer with this cable in it and it works fine. Is there supposed to be a fuse next to the cable? I felt around and did not find a fuse but I found a pic of the back of the HU and it had a fuse there. I have no idea if it was for that though, just a thought.
Old Feb 1, 2010 | 06:52 PM
Motor On's Avatar
Motor On
Can you get it into Aux mode with nothing in the port? Is the iPod running off the battery or a power supply? Are you sure that the port was in tight when it was installed? Has it worked before and/or with other devices plugged into the port?
Old Feb 1, 2010 | 06:57 PM
dcarrier's Avatar
dcarrier
I've never been able to get it into AUX mode, only CD and radio. The iPod is running off of battery. I got the plug as tight in the port as I could, it clicked into place and everything. I'm not sure if it was ever worked before I just purchased the car a week ago and was looking forward to do this. Thanks for the help thus far.
Old Feb 2, 2010 | 06:26 AM
dcarrier's Avatar
dcarrier
Anybody else have any ideas?
Old Feb 2, 2010 | 09:34 AM
rkw's Avatar
rkw
With the aux cable plugged in, Aux mode should be available even with nothing connected.
If you already tried unplugging/replugging the connector, I think you need to pull the headunit (it's not difficult) so you can visually check how well the connector is seated. You'll also be able to verify the manufacture date of the headunit (printed on a label).
Old Feb 7, 2010 | 01:49 PM
dcarrier's Avatar
dcarrier
Alrighty, so I pulled the head unit and tired to reconnect and reconnect some more. Check fuses and everything and I still cannot get this thing to work. I have taken pics of what my sticker on my head unit is: Aux Input not recognized problem-020710162353.jpg
Any advice on where to go from here would be GREATLY appreciated. Thanks
Old Feb 7, 2010 | 06:09 PM
dcarrier's Avatar
dcarrier
Anyone have any ideas?
Old Feb 8, 2010 | 10:32 AM
rkw's Avatar
rkw
You've done what I would have done. The headunit's manufacture date is new enough that it should have the aux feature. I think you're down to determining whether the cable or headunit is defective. The cable is under warranty if you bought it from a dealer.
W0TM8
Dec 19, 2019 07:50 AM
khumpert
Nov 30, 2015 11:48 AM
Longjas
Factory JCW Talk (2009+)
Nov 2, 2015 02:28 PM
D3nZem
Aug 30, 2015 07:05 AM
PEterChoqu
Aug 26, 2015 08:33 AM
