Navigation & Audio Auxiliary input on H/K system
Old Jan 27, 2010 | 07:17 AM
dcarrier's Avatar
dcarrier
I have read many postings on purchasing the Aux input connector for a mini (this one)
http://www.minicarparts.net/Parts/M3367.cfm
I wanted to know if anyone managed to get this to work with a mini with the H/K sound system. I think I have the stock head unit (but I'm not 100% sure). I have a 2004 MCS with the upgraded H/K speakers. I just purchased this vehicle and I am very anxious to get my iPod running on this. Any help would be much appreciated. Thanks
Old Jan 27, 2010 | 09:16 AM
rkw's Avatar
rkw
That is the correct cable to use.
The instructions on that site will work but are more complicated than necessary. It can be installed without removing the radio. You can pull down the drivers side knee panel, then reach around and plug the cable into the lower left corner of the radio by feeling. You can put the jack end at any location you prefer, not necessarily in the glovebox.
Old Jan 27, 2010 | 09:30 PM
PaulWalliDumali's Avatar
PaulWalliDumali
I have a cheap way! It sounds pretty good, but didnt really test it out yet. Would you like to know how or you already got it?
Old Jan 28, 2010 | 08:43 AM
smurfette26's Avatar
smurfette26
I have used the aux input on my 05 MC, I have the H/K upgrade. It was my understanding that some radios do not have the aux input jack on the back. I think the year they started putting the jack in was in 2004. Do you know if you have the jack? If so, it should work for you! Good luck!
Old Jan 28, 2010 | 08:55 AM
PaulWalliDumali
Oh, mine works, but i did it w really cheap way. Im talking about under five dollars and some labor from yourself cheap. It works pretty well.
Old Jan 28, 2010 | 11:26 AM
daflake's Avatar
daflake
Yes, HUs before late 03 do not have AUX thus the cable will not work.
Old Jan 28, 2010 | 12:39 PM
ECHO-313's Avatar
ECHO-313
Mine pluged into the amp in the back on the passagners side
Old Jan 28, 2010 | 03:17 PM
joe_bfstplk's Avatar
joe_bfstplk
What's the cutoff point for that? I have an '03 MCS, and it would be great to have an input for an MP3 player or iPod or something so that I could easily transport tunes. CDs are a pain to deal with....
TIA!
C ya,
Dutch
Old Feb 10, 2010 | 03:34 AM
tupelomsgirl's Avatar
tupelomsgirl
Does anyone know where I can buy a Harmon Kardan Drive and Play 2 ?
It seems they are discontinued.
Old Feb 10, 2010 | 06:40 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Old Feb 10, 2010 | 06:59 AM
tupelomsgirl
Thanks, those only show Drive and Play 1, not 2.
Looks like they are not available anymore.
Old Mar 29, 2011 | 11:22 AM
TigerDave's Avatar
TigerDave
Sure, NOW you tell me! After I spent 3 hours removing the center console, side fascia and then finally the radio. Ironically, I had pulled open the drivers side knee panel so I could access the top hex bolt holding the left silver fascia on!
Old Mar 29, 2011 | 02:32 PM
mininvy's Avatar
mininvy
TIA!
C ya,
Dutch
Joe_bfstplk:
Depending on your build date. The radio from my old July 2003 with Harmon Kardon had the aux port in the head unit. Also, a friend and I installed the MINI ipod cables and he has a build date of Feb 2003, also had the Harmon Kardon system. Check your built date, probably have it.
Another option would be to purchase a "Dice" kit if you have the CD changer wiring located in the rear. Open up the rear interior trim panel in the boot on the passenger side the wiring should be their.
Cheers,
Old Mar 29, 2011 | 02:45 PM
CRoth's Avatar
CRoth
I have an iSimple cable that connects the iPod / iPhone to the cd changer hook-up in the boot. If you don't have a cd changer the plug will be back there capped off from the factory.
This cable works great and let's you control your iPod through your steering wheel controls. I don't need it anymore because I upgraded my stereo system and my iPod connects directly to my Alpine head unit.
If anyone is interested, I'll sell it for $60 shipped.
Chad
xpunisherx
Nov 27, 2015 03:32 PM
Witsticka
Sep 15, 2015 01:33 PM
Filmy
Sep 7, 2015 08:27 PM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
Ntety
Sep 2, 2015 08:39 PM
