R55 Ticking Noise when accelerating
Old Jan 22, 2010 | 06:18 PM
Kimbo80's Avatar
Kimbo80
I have a '09 Justaclubman with 3873 miles. I will be bringing my car in for the 1 year maintenance in February. Recently, when I was driving with the radio off, I noticed a very faint, fast ticking noise when I accelerate.
There are two strange things about the noise a) I can only hear it when I am accelerating gently, because if I stomp on the gas the engine noise completely masks the ticking noise, and b) it only starts up once the engine is warmed up. Since I bought the car, I have only used Shell Premium (93 octane) . I am going to go buy a bottle of Techron and fill up at BP ( we don't have Chevron in IL or any other Top Tier Gas Stations nearby other than Shell) to see if it's bad gas, but have you guys ever noticed this sound?
Old Jan 23, 2010 | 04:17 PM
bad venge's Avatar
bad venge
I'd examine the tire treads closely I picked up a similar noise and it was a screw stuck in the tire ... could also be a rock wedged in
Old Jan 23, 2010 | 04:29 PM
lhoboy's Avatar
lhoboy
Might also be a bad CV joint. Does it get louder while accelerating around a street corner?
Old Jan 23, 2010 | 04:56 PM
JamesHunt's Avatar
JamesHunt
lifters and injecters make ticking sounds. ticks are ok loud knocking is not.
Old Jan 23, 2010 | 05:07 PM
Kimbo80's Avatar
Kimbo80
Thanks for all the replies. I don't think it's a CV joint, because it isn't around corners or when steering the car. It's only when I hit the throttle gently and only when the car is warmed up. It is definitely a ticking noise and not a knocking noise.
I don't know if this is related, but within the last 4 months, I have had to top off my coolant (BMW coolant/distilled water 50/50 mixture) twice (second time this morning). The coolant level never went below minimum, when I checked on a cold engine, but level has gone down from where I topped off the coolant (half way between min and max). I guess I will have to bring this up with the service dept. in the next month, because I don't see any fluid underneath the car unless it's an internal leak.
Old Feb 1, 2010 | 05:13 PM
DragonWagon's Avatar
DragonWagon
Is your wife mad at you?
She may have hired a hitman who installed a cheap, alarm clock bomb.
Hey, it could happen. Look under the dash.
Old Feb 2, 2010 | 09:05 AM
mbu's Avatar
mbu
I have a '09 Justaclubman with 3873 miles. I will be bringing my car in for the 1 year maintenance in February. Recently, when I was driving with the radio off, I noticed a very faint, fast ticking noise when I accelerate. ...
Kimbo80,
After the maintenance check, would you mind posting back here and tell us what the mechanic said about this condition?
Thanks...
Old Feb 2, 2010 | 05:05 PM
Kimbo80's Avatar
Kimbo80
Originally Posted by mbu
Kimbo80,
Thanks...
Absolutely. I have been slammed at work lately, but I should be going in before the end of the month for my one year maintenance. Most likely I will have to drive with the technician. Are you experiencing a similar sound?
Old Mar 3, 2010 | 06:30 PM
maxim2112's Avatar
maxim2112
My 09 Clubman S is experiencing the same thing. I only hear it at partial throttle. Stops immediately when it goes on vacuum. Doesn't seem to be RPM dependent. Sounds like something is arching on the passenger side of the engine.
Old Mar 3, 2010 | 06:43 PM
Kimbo80's Avatar
Kimbo80
I took my car in a couple of weeks ago. The SA said it was normal. Based on the threads I have researched on NAM, a lot of other members hear the same thing. I guess as long as it's not knocking, we are ok.
https://www.northamericanmotoring.co...oise-idle.html
Doc Pain
Mar 10, 2021 04:50 AM
minieater
Oct 28, 2015 02:15 PM
unxpectederror
Oct 22, 2015 12:16 PM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
