R50/53 2006 mini checkmate S ?
hello, just picked up today a 2006 mini checkmate S model, with the checkmate package did any engine upgrades come with it? this one has a airbox lid that reads john coopers works? it looks like it still has the stock exhaust, with beer can tips.
thanks for any info on the checkmate.
mike
mike
I personnally think the Checkmate was the best of the special editions when you consider the interior package and clean graphics.
Congrats on your purchase! How many miles are on the odometer?
now if i only can get the 2nd key fob to work? need to see one opened up, maybe can clean the contacts?
all my searches come up with that suggestion also. well i drive 2 hours a day, how long does it need? still do not understand how? there is only one contact point? unless it is completing the electrical circuit when the key is inserted? like a simple pull circuit?
ok here is the technical info
The new key also had three buttons, but, the LED did not carry over. is permanantly sealed and contains a rechargeable battery. Supposedly the battery should last the life of the car. The battery is recharge when in the ignition via the EWS ring antenna.
http://www.bmwgm5.com/Keys.htm
Recharging the battery in the new key fob. If not used the key will be discharged in approximately 18 months. It requires approximately 30 hours to fully charge a completely discharged battery. The remote can be operated 15 times after being charged for 30 minutes. Charging only occurs when the ignition is in the Accessory or On positions. It does not charge in the Off position.
when is a good time to call? thanks it frustrating, tried the turn the key on, off, out key unlock hold lock 3 times thing? no luck well at least one key fob works.
thanks for your help, mike z
I have basically the same car, without the Checkmate package...Space Blue, Silver roof, Silver Checkmate Bonnet Stripe,silver mirror caps.
I'm just missing the seats, steering wheel and fender badges. I guess I got the left overs.
thanks way for your help with the key fob, i took the jcw airbox lid off, as i noted the vac line and power was not hooked up! the flap was closed, ok i did the flap open mod, then i noticed no hole was ever cut for the incoming air on the engine back wall! who what a difference in sound, did not go for a ride yet, thanks again NJ mike
Key fob battery connection breaks
SosoMINI
Nov 22, 2015 03:17 PM
