Suspension Powerflex Lube Frequency
Old Jan 6, 2010 | 06:38 PM
okieflyr's Avatar
okieflyr
So I'm about to finish the Powerflex control arm bushing install,on our 05 MCS and I'm looking at the little packet of lube and now I'm wondering how often these will need to be serviced in daily driver duty. It would be easier to put a zert
into it now that it's out, although I'm thinking it may be overkill.
What kind of servicing cycle should I expect?
Kevin
Old Jan 6, 2010 | 07:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've got several customers that have had them for 2yrs plus and never had to regrease them. I wouldnt worry too much about it.
Old Jan 7, 2010 | 05:38 PM
okieflyr's Avatar
okieflyr
Powerflex lubrication
Thanks Way,
Thinking about more, It shouldn't be near as difficult to service now that everything has been seperated and anti-siezed. They use a lotta salt and sand up here! Hopefully I get a box-o-joints tommorow and I can button this back up.
Old Jan 19, 2010 | 11:54 AM
meb's Avatar
meb
Depedns on your mileage...I re-lubed mine once a year. I drove nearly 60,000 miles a year. The LCA still moved with ease, but much better when re-lubed.
You can remove the axles instead of the sub-frame to access the bushings; once the axles are removed, remove the front ball joint bolt, lower the LCA (might require a bit of work) and then slide the LCA out of the bushing. Much easier than removing the subframe.
Old Jan 20, 2010 | 05:46 PM
okieflyr's Avatar
okieflyr
Lube
Wow!
I thought I had a commute.
I figured that since everything has been freshened and anti-seized, things will be much less drastic and drama to gain access for service.
Kevin
Old Aug 6, 2010 | 05:24 AM
xristos's Avatar
xristos
Does powerflex recommend lubing them or do people do it for extra protection.
Old Aug 6, 2010 | 06:40 AM
T0mmy's Avatar
T0mmy
They reccomend it. Powerflex ships ketchup packet sized lube with bushings that require it, and their instructions show where to use it.
Old Aug 6, 2010 | 10:04 AM
xristos's Avatar
xristos
Would you relube again it after the initial installation or just that first time?
patsum
26
May 29, 2021 06:29 PM
YaTuSabe
Aug 23, 2018 11:41 AM
Mrbrown
Suspension
11
Dec 31, 2015 09:31 AM
pahg
Oct 5, 2015 11:50 AM
Emnotek
Sep 29, 2015 07:37 AM
