Navigation & Audio iPhone mounting bracket suggestions?
Old Jan 5, 2010 | 08:00 AM
KrautHammer's Avatar
KrautHammer
Apologies first as the subject has been beaten around a lot.
After quite a long time I decided that it would be prudent to have the iPhone on a solid bracket, charging and hands free talking.
Picked up a Belkin kit yesterday for $91 at Costco which promised to do all of that but the quality was poor and inserting/removing the phone would have damaged the bracket and/or the phone in short time.
Any good devices out there that will fit the Mini? The Apple store has several but they are mostly cigarette lighter anchored and some will definitely not fit the tight angles of the Mini.
Thanks all.
Old Jan 5, 2010 | 08:18 AM
Flyinace2000's Avatar
Flyinace2000
I got this for christmas. Works wonderfully!
http://www.cravenspeed.com/index.php?productID=256
Old Jan 5, 2010 | 09:01 AM
Xeraux's Avatar
Xeraux
RAM Mount.
I have this one when I'm using the Navigon MobileNavigator software. Inexpensive, stout, and fully removable when you're not using it.
http://www.ram-mount.com/CatalogResu...5/Default.aspx
Old Jan 5, 2010 | 10:34 AM
KrautHammer
Thanks guys.
I'm wishing for something that will charge and allow hands off telephony at the same time.
Old Jan 6, 2010 | 05:30 AM
schatzy62's Avatar
schatzy62
KrautHammer,
It sounds as if you do not have bluetooth built in in the car. If this is true there are a number of good Parrot kits for that. http://www.parrot.com/usa
there are some other bluetooth systems out there but parrot seems to have the wides range of options. These will play thru the radio and mute the radio when a call is in progress.
Newministuff has wiring harnesses for the Parrot Bluetooth kits that make them completely hidden and plug and play. http://www.newministuff.com/new/index.php
for mounting a Craven mount is probably your best bet but there are other options from ProClip and Kuda as well.
http://www.proclipusa.com/
http://www.kudausa.com/
Old Jan 6, 2010 | 01:20 PM
KrautHammer
schatzy62 you are a wealth of information and yes you are correct in that I don't have integrated OEM Bluetooth.
The Parrot website is most interesting. Many thanks.
Old Jan 6, 2010 | 01:24 PM
C H I C K L E T's Avatar
C H I C K L E T
+3 on the Craven Speed mounts...very nice quality and great customer service!
Old Jan 6, 2010 | 09:03 PM
Robin Casady's Avatar
Robin Casady
I have this mount for having the iPhone where I can see it while driving. Previously, I've been using an Apple Universal Dock on a platform I made for the cup holder. When I want the iPhone in the Craven dock running Dynolicious, MINI Wave, etc., I'll use an iPod in the Unviversal dock for music.
Old Jan 7, 2010 | 08:38 AM
jameszimo's Avatar
jameszimo
iphone mounted with Kuda base/ProClip mount and a Griffin Autopilot for charging and aux input. I supplied power to the Autopilot with an add-a-fuse behind the dash.
Old Jan 7, 2010 | 08:53 AM
schatzy62's Avatar
schatzy62
Do you have a more straight on picture (from teh back seat maybe) of the mounting. I did not see one in your gallery but I may have missed it.
Old Jan 7, 2010 | 08:56 AM
jameszimo's Avatar
jameszimo
Not yet... I'll have to take one later today. There may be one in NAM somewhere as I got all my ideas from this forum.
Edit: quick search didn't turn up much so I'll be sure to take one later...
Old Jan 7, 2010 | 09:06 AM
schatzy62's Avatar
schatzy62
Thanks. This is one of my next projects so that my phone does not float around the passenger seat or center console.
Old Jan 7, 2010 | 09:15 AM
Tron Chief's Avatar
Tron Chief
Here is another option and it works will all generations of the Mini Sorry for the bad picture taken with a blackberry however the thread link at the bottom does have several options that SRTech has available. The phone adapter can be for a blackberry or Iphone can be used with the gauges or without.
https://www.northamericanmotoring.co...gauges-22.html
Old Jan 7, 2010 | 10:29 AM
KrautHammer
This is the Belkin that I used and found to be inadequate. Buyer beware.
http://store.apple.com/us/product/TY...1&s=topSellers
Old Jan 7, 2010 | 01:29 PM
Robin Casady
Look at the reviews at the Apple Store. 1.5 stars.
Old Jan 7, 2010 | 01:46 PM
Robin Casady
Since you don't have the Bluetooth/USB option, you need something to charge the iPhone. I've had good luck with a Powerjolt USB car charger for iPhone. This works well with the Apple Universal Dock because the dock has a 3.5mm audio out port as well as the dock connector port. So, you can plug in the charger, and have audio out from the iPhone's dock port connected to the AUX in.
Old Jan 8, 2010 | 01:15 PM
KrautHammer
Nice setup Robin. Does the iPhone stay put on the Apple dock during cornering, bumps, flights and landings?
Old Jan 8, 2010 | 02:12 PM
Robin Casady
The only time it has moved and lost its connection is when I hit it with my knee. The solution is to use the passenger cup holder if your knee tends to hit the cup holder often.
I drive on some very bumpy roads and that hasn't bee a problem. However, I don't get my MINI airborne very often.
Old Jan 8, 2010 | 02:40 PM
jameszimo's Avatar
jameszimo
here you go:
Old Jan 8, 2010 | 03:53 PM
KrautHammer
... However, I don't get my MINI airborne very often.
Not so here as I frequently thank the day when I installed the strut bar.
OK jameszimo , quite nice but what are we looking at and what is that App on the screen?
Old Jan 8, 2010 | 04:15 PM
jameszimo's Avatar
jameszimo
Hi KrautHammer, schatzy62 wanted a straight on shot of the iPhone mount I've been using. The app is KCRW radio station streaming.
Old Jan 9, 2010 | 06:46 AM
KrautHammer
Ah, ECLECTIC24. You guys may have rain but you have good coffee and good music.
Old Jan 10, 2010 | 10:38 PM
paul_voorn's Avatar
paul_voorn
Old Jan 15, 2010 | 08:49 PM
rhsant's Avatar
rhsant
Kuda / Proclip
Jameszimo -
That looks like a pretty sweet setup. Do the Kuda base and the proclip mount work together, or did you have to do some manipulation to mount the proclip on the kuda base?
Thanks,
Rich
Old Jan 16, 2010 | 06:06 PM
jameszimo's Avatar
jameszimo
Originally Posted by rhsant
Jameszimo -
Thanks,
Rich
rhsant,
If I remember right, the ProClip mounting holes lined up with the Kuda base (it was a while ago that I did the install).
hope that helps!
