Suspension MCS stance
Old Jan 3, 2010 | 12:30 PM
R53's Avatar
R53
MCS stance
Ive noticed that all mini's (standard) - even lowered ones too, the back sits lower than the front. Why is that? My understanding is that on most cars the back is usually raised a little than the front as there is more weight in the back when carrying passengers and luggage, the engine also sits in the front end of the car, hence it being a tad lower?
Can some care to explain! thanks
Old Jan 3, 2010 | 01:22 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Takes longer for front springs to settle in.....eventually they will even out after you put some mileage on them. But most don't wait long enough to take the first photos of their new lower stance.
Old Jan 3, 2010 | 01:26 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
It's just a trick of the eye. The rear wheel wells are noticeably smaller than the front ones so it looks like there is less wheel gap in the rear which leads the viewer to beleive that the rear is lower. If you actually measure the sideskirts you'll find that most MINI's have front rake.
Good example image. You can see that I tuck more wheel in the rear which makes the mind think that the car has reverse rack. Then you look at the sideskirts and notice that the car is much lower in the front. The uneven tuck just happens because of the wheel well size variance. It's a common thing among car designs now.
Old Jan 3, 2010 | 03:32 PM
-=gRaY rAvEn=-
Moderator
Rally, I thought you were running bags and not springs/coilovers.
BTW: your Clubman l@@ks Awesome ! The rims are a perfect match to the whole car.
Old Jan 3, 2010 | 04:21 PM
Professor's Avatar
Professor
He is.
Old Jan 3, 2010 | 04:55 PM
Rally@StanceDesign
I am....the wheel wells are still different sizes.
The slammed ride height just makes the point more visible.
Old Jan 3, 2010 | 05:38 PM
Some Guy's Avatar
Some Guy
I know this thread isnt about your car, but that looks SWEET.
Old Jan 4, 2010 | 05:17 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Rally - great explanation. Something I had noticed, but never really thought much about. Good stuff.
Old Jan 4, 2010 | 10:15 AM
R53's Avatar
R53
I thought it was that! Great explanation Rally. And your clubman looks good
wildwestrider
Dec 27, 2015 08:20 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
