Navigation & Audio For those with HIFI who replaced their speakers
Old Dec 17, 2009 | 11:56 AM
LaserBlue07MCS's Avatar
LaserBlue07MCS
Just wondering what speakers everyone went with. I have seen this information scattered around in various posts and thought it would help to get this in one place.
So, for those with the HiFi who replaced their speakers: What speakers did you get and did you add an amp?
Old Dec 17, 2009 | 01:07 PM
Robin Casady's Avatar
Robin Casady
First used the following speakers with the HIFI amp:
Infinity Kappa 693.7i 6"x9" 3-way car speakers
Infinity Kappa 60.7cs 6-1/2" component speaker system
Infinity Kappa 42.7i 4" 2-way car speakers (didn't connect the tweeters)
Added a Boss Bass600 sub to fill in missing bass.
Sound was too bright (harsh) for my taste. So, went with the following:
Q 450.4 - Image Dynamics 4-Channel 450 Watt Amplifier
CXS64 V.2 - Image Dynamics 6.5" 4 ohm Component System
CTX69 - Image Dynamics 6 x 9" 2 Way Speaker w/ Silk Tweeters
Still using the Bass600.
I'm very happy with this sound system. While the Kapas provided more clarity than the stock HIFI speakers, the Image Dynamics system produces a very noticeable improvement in clarity over the Kappas. Sound is smooth and full.
Old Dec 30, 2009 | 01:52 PM
LaserBlue07MCS
Bump :-)
Old Dec 30, 2009 | 05:24 PM
miniSQ's Avatar
miniSQ
Not hifi...but i went with the Image Dynamics XS65 comps and am loving them. This is in an 09 MCS
Old Jan 1, 2010 | 05:03 PM
LaserBlue07MCS
I decided on the Focal 165 VR3s. Will post impressions once done with the install. I am hoping I can do this next week.
For those who also replaced their fronts (who have Hi-fi) please post their results. Seems like a great way to help other people who are looking to do the same
Old Jan 2, 2010 | 04:52 AM
miniSQ's Avatar
miniSQ
May i assume you are not going to try and power the focal comps with the factory system?
Old Jan 4, 2010 | 07:00 AM
LaserBlue07MCS
Actually I am for now. Seems that most people who add an amp do so for volume reasons. I don't like listening to music at high volumes, so I wanted to try with just the stock Hi-Fi amp first before spending any extra money and time adding an amp.
Old Jan 4, 2010 | 09:25 AM
Big Jim Swade's Avatar
Big Jim Swade
Before you replace your Hi-fi speakers, you might read through this post and try it first.
https://www.northamericanmotoring.co...-in-front.html
Old Jan 4, 2010 | 03:34 PM
miniSQ's Avatar
miniSQ
How are you planning on handling the crossovers?
Old Jan 4, 2010 | 06:22 PM
LaserBlue07MCS
Based on everything I've read on this forum, I don't need to use the Focal crossovers.
Old Jan 5, 2010 | 01:42 PM
Robin Casady
I didn't add an amp for volume. I don't like loud volume either. I had two reasons:
1. To bypass the odd signal processing and/or filtering in the HIFI amp.
2. Improve sound quality. A high quality powerful amp will improve sound quality. I've found this to have very noticeable effect when upgrading amps in my home system.
There is already some filtering done in the HIFI amp, so you probably don't want to add crossovers on top of it, at least in some places. The lower 6.5" speaker seems to get mostly bass.
However, I believe the upper speaker gets full range. So, you might want to try using the crossover for the 4" speaker. If you are mounting the tweeter in the door, you could use it for that as well.
If you are putting the tweeter in the A-pillar, it think there is already a high pass filter in that wiring.
Old Jan 8, 2010 | 12:35 PM
LaserBlue07MCS
What amp did you end up going with again? Starting to think about it.
Old Jan 8, 2010 | 12:55 PM
Robin Casady
woodstudio
Mar 15, 2020 08:28 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
bugeye1031
Aug 15, 2015 08:14 AM
OutMotoring
Aug 6, 2015 09:32 AM
