PDC no longer working after new clutch
Old Dec 4, 2009 | 12:58 PM
cabriopilot's Avatar
cabriopilot
PDC no longer working after new clutch was installed by dealership.
Is it a coincidence or did they forget to reconnect something?
My MINI is now out of warranty so I don't want to pay them to fix
something that I may be able to fix my self.
Any suggestions??
Old Dec 8, 2009 | 03:26 PM
kenatminimania's Avatar
kenatminimania
Check to see if the fuse for the power steering fan is blown - this will disable PDC.
Old Dec 8, 2009 | 08:13 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
So, uh, what's PDC then?
Old Dec 9, 2009 | 03:35 AM
AXracer's Avatar
AXracer
Park Distance Control.
Two things to look at,
First make sure they plugged in the rev light switch on the trans, if the rev lights dont work either the switch is most likely unplugged.
Second, the fuse to the PDC is also for the P/S fan, if the fan locks up or is going bad it will blow the fuse and the pdc will not sound but the rev lights will still work.
Old Dec 9, 2009 | 03:43 AM
AXracer's Avatar
AXracer
Left out switch location. DUH
On the R52-53 W11 Cooper S The rev light switch is located on the back of the trans under the air box area under the shift linkage. You may be able to see it thru the driver side wheel area as well, you would likely have to remove the tire.
eliseo1981
Jan 28, 2021 02:45 PM
W0TM8
Dec 19, 2019 07:50 AM
emulajavi
Dec 24, 2018 09:15 AM
PrimePower
Aug 16, 2015 06:29 PM
Getrieben
Aug 15, 2015 09:09 PM
