R56 LSD into a R56??
Old Dec 3, 2009 | 10:11 PM
R56 HOOLIGAN's Avatar
R56 HOOLIGAN
LSD into a R56??
Is anyone aware of the possibility of swapping a used R53 LSD into a R56? I have an '07 MCS with sport mode & a gang of ALTA suspension/intake/tubes/exhaust gear in it & H&R coils. I plan on tracking/auto-xing the car in the future & just wonder if they are compatible. If not, I will hold out for a Quaife.
Old Dec 3, 2009 | 10:49 PM
Btwyx's Avatar
Btwyx
Why not the OEM LSD from an R56? (I've no idea if they're the same or different, but why the R53 one rather than an R56 one?)
Old Dec 3, 2009 | 11:18 PM
Robin Casady's Avatar
Robin Casady
Isn't the 2nd Gen manual transmission entirely different than 1st Gen? I'd be surprised if the old LSD fit.
Old Dec 4, 2009 | 04:55 AM
Porthos's Avatar
Porthos
Ya probably won't work just get the r56 one or the OS Giken one.
Old Dec 4, 2009 | 06:50 AM
AutoXCooper.com's Avatar
AutoXCooper.com
The Giken one works on the R53 and R56S.
Old Dec 4, 2009 | 07:38 AM
hardingsan's Avatar
hardingsan
probably because all the gen 2 LSDs are electronic systems now, making them smart brakes, and not LSDs.
Old Dec 4, 2009 | 07:53 AM
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
Not so sure about that ... the smart braking is part of the DSC, but LSD is still mechanical, which is not to be confused with EDLC.
I've heard they're doing away with the LSD option, but it still shows as being available on the MINI configurator.
Old Dec 4, 2009 | 07:57 AM
hardingsan's Avatar
hardingsan
doing away with LSD on 2010 models, but starts Sept 09, via motoringfile; so already in effect?
not sure if the configurator would differentiate between LSD and eLSD if they'd only offer one or the other.
http://www.motoringfile.com/2009/07/...slip-for-2010/
Old Dec 4, 2009 | 08:15 AM
KevinC's Avatar
KevinC
No, the cutoff is sometime early next year (January?), as of now, you can still order it. Alas I left it off my build, and when I changed my mind later the same night, by the time I tried to add it the next morning, my car was already into production. Not a big thing since I'll likely never track or autocross the car, but still now wish I had it.. especially so close to the cutoff date. '10's with LSD will be rare birds indeed.
Old Dec 4, 2009 | 10:20 AM
Robin Casady
not sure if the configurator would differentiate between LSD and eLSD if they'd only offer one or the other.[/URL]
EDLC (it is not eLSD) is part of the DTC option. LSD is pictured as a mechanical device. They are distinctly different in the Configurator. I'd get both if I were ordering now.
Old Dec 4, 2009 | 11:26 AM
Porthos's Avatar
Porthos
Don't even bring the Elsd into it you can still get the mechanical one if you order it.
Old Dec 4, 2009 | 12:13 PM
Romo.'s Avatar
Romo.
How much would it cost to retrofit an OEM LSD or one of the aftermarket ones?
Old Dec 4, 2009 | 01:10 PM
AutoXCooper.com
Hi Romo, it varies on the labor rate. You need to remove the tranny, open it up, install LSD, put it all back together and put back in car. Most shops will want 14-16 hours for the job.
Old Dec 4, 2009 | 01:46 PM
LiLReD1's Avatar
LiLReD1
What's the cost for the LSD? I really could use one in mine. Love the JCW torque, but do not like the one wheel wonder.
Old Dec 4, 2009 | 03:00 PM
AutoXCooper.com
The Giken is only $1590.00
Since it's a large investment of labor, yours or a shops, you might also want to do the clutch at the sametime if you think you might need one. We've seen guys toast a clutch in under 50K and other get more then 100K it's just up to you. The Giken clutch with flywheel is also $1590.00. Can also get other good clutches with flywheel for under a $1000.00
Also want New Bearings only $50.00 a set and 2 qts of Royal Purple Synchromax $28.00
If you are thinking about this set up and need a supplier please drop me an email at dustin@autoxcooper.com Thanks Dustin
Old Dec 4, 2009 | 03:54 PM
thevelourfog's Avatar
thevelourfog
If I was going to go through all the trouble of adding a LSD to an R56, I'd get something with better lock % than the OEM unit. Get a Quaife or OS Giken.
Old Dec 4, 2009 | 06:23 PM
Btwyx's Avatar
Btwyx
He's putting it in a 07, they had mechanical LSDs until sometime last year. (I know they did in 08 anyway, Shawn has mechanical LSD.)
Old Dec 4, 2009 | 07:24 PM
Crashton's Avatar
Crashton
As of today a the mechanical LSD is still able to be ordered in a new R56 MCS. I have read somewhere that it's days are numbered. To be replaced by another electronic traction nanny (DTC).
rtk90
Aug 29, 2019 09:08 AM
newowner
Sep 15, 2015 07:18 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
Anakist
Australia
Sep 8, 2015 03:32 AM
Sep 4, 2015 01:32 PM
