Suspension IE Fixed Camber Plates Question
Old Nov 21, 2009 | 09:29 AM
jeff_scooper's Avatar
jeff_scooper
I'm looking to install these camber plates on my 2005 MCS. Do installing these camber plates require that I compress the springs? Is there a thread on how to install camber plates? FWIW, everything else on my front suspension is stock. I'm looking for better corning performance for autocross. I already have a stiffer rear sway bar, and Dunlop Drizza Sport tires.
Old Nov 21, 2009 | 09:37 AM
IanF's Avatar
IanF
Yes, you'll need a spring compressor. Installing the camber plates is basically the same as R&R'ing the struts. It replaces the upper strut mount which retains the upper spring perch. Any of the threads about R&R front struts will work for you. You MUST get the car aligned IMMEDIATELY after the install, or you risk tire wear.
Old Nov 21, 2009 | 10:56 AM
AutoXCooper.com's Avatar
AutoXCooper.com
many local parts store will rent you a spring tool for free for the day. It's also an easier job with a 2nd set of hands. IanF is right about the alignment, while the camber will be fixed the TOE must be re-set.
Old Nov 21, 2009 | 11:52 AM
jeff_scooper
Thanks guys.
Old Nov 21, 2009 | 04:34 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Here's keith's definitive how-to for spring install - camber plate process is EXACTLY the same - you're just now changing springs.
https://www.northamericanmotoring.co...ll-how-to.html
I manage to use tie down ratchet straps when I do this with no worries.
Old Nov 23, 2009 | 08:17 AM
Bigshot's Avatar
Bigshot
If you are going to AutoX with those mods you will no longer be in stock.
Old Nov 23, 2009 | 08:47 AM
BlimeyCabrio
A very good point.
Old Nov 25, 2009 | 09:13 AM
jeff_scooper
I autocross with the Houston BMWCCA club. Their classifications are different from SCCA.
W0TM8
Dec 19, 2019 07:50 AM
WestfaliaR
Aug 19, 2015 08:01 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
