Navigation & Audio What would you do on a budget of $500 or less
Old Nov 15, 2009 | 03:40 PM
Flyinace2000's Avatar
Flyinace2000
So i opted to not get the HiFi system when i ordered by 09 MCS. My 07 had the HiFi and i thought i could do better for the money.
So with a budget $500 or less what would give me the biggest bang for my buck? I a comfortable doing all the work myself and i want to keep it close to stock looking as possible. Do i just replace the speakers in the doors and do the rear/front channel swap? Do I bite the bullet and swap out the rear 6x9s? What brand speakers?
Thanks All.
Old Nov 15, 2009 | 04:29 PM
miniSQ's Avatar
miniSQ
replace the fronts with these:
http://www.sonicelectronix.com/item_...PPI+356CS.html
find them on ebay with free shipping.
Leave the 6x9's alone...
Throw in a powered sub...maybe the infinity basslink 2.
done.
Old Nov 15, 2009 | 04:37 PM
Flyinace2000
Where would i put the infinity basslink 2? Trunk? How do i get the audio to the sub? Does it simply take one of the speaker feeds and filter our the high end?
Old Nov 15, 2009 | 04:44 PM
Flyinace2000
Also, if i get those Precision Power PPI 356CS do they just replace the one speaker in the door leaving the other one stock or are the precision speakers enough to not have to worry about the other door speaker?
Old Nov 15, 2009 | 05:07 PM
miniSQ's Avatar
miniSQ
yes, it ( or any other powered sub) would be anchored int he boot and pick up signal wires thru the front speaker leads. You can search for how to do this in a million places here.
Old Nov 15, 2009 | 05:10 PM
miniSQ's Avatar
miniSQ
they are component speakers...you would pull both speakers out of the front doors and replace them with the components...and the crossover owuld mount in the armrest...
But i am confused...you say you have no problems doing all this yourself..but yet you seem pretty new to car audio? Are you sure you can dig into this car??
Here is a nice build to look at some of what you will be up against...
http://www.diymobileaudio.com/forum/...ooper-r56.html
Old Nov 15, 2009 | 06:59 PM
Flyinace2000
I re-did my old car with new speakers and a head unit a few years back. So yes, i am somewhat new but i am a fairly technical guy so i should be able to handle it with the proper research.
Old Nov 15, 2009 | 07:12 PM
Robin Casady's Avatar
Robin Casady
I don't know anything about the PPI 356CS speakers, so can't comment on those.
For picking up signal for the powered sub, see this thread on the Bass600. However, I'd refine how the connection is done, and for the standard audio, use the high-level inputs (if you end up with the Bass600).
The cleanest way to do it is to buy both halves of the X9331 connector (and all the pins and sockets) then make a pass-through connector that has eight wires going to the sub. Shielded data cable (CAT6, I think) works well. There are a number of threads on the X9331. Check them out for part numbers, etc.
Old Nov 15, 2009 | 07:24 PM
Flyinace2000
So basically you would make a man in the middle attack on the audio signal sending all channels to the sub for processing while still sending the audio to all the speakers in the car.
Old Nov 15, 2009 | 08:11 PM
Robin Casady
With the standard audio, I might just send the front channels to the sub, but otherwise, yes.
Old Nov 16, 2009 | 02:29 PM
miniSQ's Avatar
miniSQ
Correct....just the front speakers go to the sub. And he is going to have a tough time keeping his budget to $500 if he spends $100 just on the plug connectors...no reason he can't tap in front of the harness if he is neat and clean. You can then just disconnect when you trade it in and wrap hockey tape around the wires.
PS those PPI speakers are very good comps
Old Nov 16, 2009 | 02:36 PM
Robin Casady
Speakers $140
Sub $100-$200
X9331 connector $70 (or less)
That leaves $90 for tax, shipping, and misc. and he will be able to take his car back to stock if needed.
Old Nov 16, 2009 | 03:14 PM
pilotart's Avatar
pilotart
How about that front/rear channel swap for free,
there is a long thread here on that mod for the base MINI Sound System.
Old Nov 16, 2009 | 07:34 PM
10Zero's Avatar
10Zero
Works wonders too I might add...
Old Nov 16, 2009 | 08:42 PM
Robin Casady
Yea, but how are you going to spend $500 just doing the channel swap?
Old Nov 24, 2009 | 07:47 AM
Flyinace2000
I would imagine the channel swap + front new speakers. I could spend 200 on new fronts as a start then move on to a sub/rear speakers if i feel so inclined. Honestly i am just looking for a little better sound w/o to much hassle. So the channel swap and new fronts sound like a good idea.
From what i read the channel swap will but the bluetooth audio to the rear speakers. Has that been much of an issue for hearing callers?
RIchard Nguyen
Sep 14, 2016 11:43 AM
danielmini
Oct 20, 2015 02:09 PM
Fourflys
43
Oct 20, 2015 09:42 AM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
nashvillemini
Sep 30, 2015 10:26 PM
