R56 lightweight batteries
Old Nov 2, 2009 | 12:29 PM
Tox_boy's Avatar
Tox_boy
Hi all
First time poster long time lurker. Have had my dark gray MCS for a week now, great fun.
Has anyone swapped out there battery for a light weight unit?
I see the Odyssey and the Braille mentioned here and there. Has anyone tried NRGCELL the list it as a daily driver. I will need to see what the CCA on the stock battery are for the factory unit.
http://www.nrgcell.com/product.php?p...6&cat=1&page=1
Old Nov 2, 2009 | 02:44 PM
AutoXCooper.com's Avatar
AutoXCooper.com
check with Chad at http://www.detroittuned.com/shop/?categoryID=88 he's got some good light weight batteries.
Old Nov 2, 2009 | 07:39 PM
Porthos's Avatar
Porthos
Just remember that you can't sit on it too long or you will drain it and have to jump it.
Old Nov 3, 2009 | 06:04 AM
Flyinace2000's Avatar
Flyinace2000
How long is too long?
Old Nov 3, 2009 | 06:50 AM
loud9266's Avatar
loud9266
the stock one seems fairly small to me
i could diet for a week and lose more weight than a battery change
bot then again im at about 215
if you delete the rear seat i hear ya lose about 30 lbs
Old Nov 3, 2009 | 03:10 PM
Porthos's Avatar
Porthos
Well the Braille street battery I think said like 45min and the race one for like 20 min
Old Nov 3, 2009 | 04:43 PM
DAVESTER's Avatar
DAVESTER
the CCA on the OEM is 450 and the one your looking at is only 300CCA....
Not enough cranking amp reserve
Old Nov 3, 2009 | 06:25 PM
LONO's Avatar
LONO
I have used a race battery in a different car. If you plan to use the MINI as a daily driver I would not recommend a race battery unless you keep a jump start battery in the boot. Since you would net a weight gain I would stick with the stock battery.
Old Nov 4, 2009 | 05:42 AM
Tox_boy's Avatar
Tox_boy
The CCA has been my biggest concern. Living in the North east it gets cold enough in the winter.
I would suspect that as a daily driver it would do better since the battery gets charged to and from work. I would assume that letting it sit for a week or two would drain it.
Old Nov 4, 2009 | 07:37 AM
Bigshot's Avatar
Bigshot
Spend your money elsewhere for a better bang for the buck. Not enough of an increase in perfromance to warrant the change. A one-ball mod will probably save as much, if not more, weight.
Old Nov 4, 2009 | 07:43 AM
slinger688's Avatar
slinger688
Braille has their "no weight" and carbon fiber batteries starting at 6.6 lbs that are purely for track/racing. I talked with them a while ago and they claim that the 15 lb battery (and up) is OK for daily use in a Mini. But to be sure especially in the cold climates, I think the 17 lb, 18.5 lb or 21 lb batteries may be better. Still a lot lighter than stock.
The 45 min quoted in an earlier post is reserve capacity, not storage time.
gnhovis
Dec 14, 2015 05:31 PM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
