R55 Speedo accuracy
Old Oct 14, 2009 | 05:32 PM
taysan's Avatar
taysan
Speedo accuracy
Not sure if others have noticed, but my 2008 Clubman (non-S) with the 17" wheel package (205/45R17 run-flats) has a bit of an optimistic speedo.
When I'm cruising at 100kph, my GPS has me at about 93.
Anyone else have this discrepancy? I'm a good 7% off.
Old Oct 14, 2009 | 05:46 PM
cmcveay's Avatar
cmcveay
It's been noted in several other threads. Most people find that it's 3-5mph off when comparing a GPS speed and the indicated speed.
Old Oct 14, 2009 | 06:06 PM
proximal's Avatar
proximal
BMW specs allow for a 10% + 2.4 mph error in this displayed speed. This is actually intentional; if you plug a ScanGauge in, it will show you the true speed.
Old Oct 14, 2009 | 06:30 PM
dbhouston's Avatar
dbhouston
My '08 with 16" wheels is only 2 mph off, which is much better than my 07 MCS with 17" wheels. It was a full 4 mph off. You learn to adjust.
Old Oct 14, 2009 | 07:04 PM
schatzy62's Avatar
schatzy62
not just several but close to fifty different threads here.
Actually it is plus 10% +2.4KPH and minus 0% and this is because many of the European nations have this as their Federal Standard.
And believe it or not (and i have tested it) that from a brand new set of 17" tires to a fully used set (down to the wear bars) there will be a 1.2 MPH difference in your speedometer. 16" are about 1.35 MPH and 18" are about 1.07 MPH
PsychoRallye
21
Feb 17, 2019 06:08 AM
neezebeeze
Oct 31, 2016 12:10 PM
JaggerCoop
Sep 15, 2015 06:17 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
