Does my Throttle Body look right?
Old Oct 8, 2009 | 06:38 PM
godzilla's Avatar
godzilla
I just installed my new DT bypass valve and I decided to clean my throttle body while I had it apart.
Does the throttle body look like it's adjusted correctly?
I thought it should be closed more but I'm no mechanic.
Old Oct 8, 2009 | 07:15 PM
tazio's Avatar
tazio
I'd hit it.
Old Oct 8, 2009 | 07:46 PM
godzilla's Avatar
godzilla
Should it be closed more or is that the way it's supposed to be?
Old Oct 8, 2009 | 09:08 PM
IceManMCS's Avatar
IceManMCS
I have one off my 2003 MCS laying right in front of me. It's appears to be slightly open, identical to yours.
Our throttle bodies don't have an idle air bypass valve or anything, so it is perfectly normal for there to be a small gap in the butterfly valve to allow air to pass through at idle speeds.
I'm not a mechanic, so someone with more knowledge than me, please feel free to correct me if wrong.
Old Oct 8, 2009 | 10:18 PM
Jonshungry's Avatar
Jonshungry
That's what mine looks like
Old Oct 8, 2009 | 10:55 PM
godzilla's Avatar
godzilla
Thanks guys!
Old Oct 9, 2009 | 06:58 AM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
That is how it should look. That slight open crack is the idle circuit. The computer will adjust as it's running, but that crack allows enough air to start the car and idle.
By the way that looks pretty clean
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Oct 9, 2009 | 07:46 AM
godzilla's Avatar
godzilla
Thanks. I used valvoline throttle body cleaner and a microfiber cloth.
Old Nov 9, 2009 | 07:24 AM
Tamadx's Avatar
Tamadx
bringing back an old thread.... sorry
but if i am correct this is why you hear that wistle after doing an intake on the MCS. in my mind is it silly that the engineers took a short cut and had the throttle stay open a little. But i am no engineer haha.
Old Nov 9, 2009 | 11:16 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Depends on what whistle you're hearing. Mine whistles at about 15% throttle - so the throttle is more opened than the "idle crack" when mine whistles. I don't think it being cracked a bit at 0% throttle impacts my whistle. But if you have whistle at idle - then maybe...
Old Nov 9, 2009 | 12:37 PM
Tamadx's Avatar
Tamadx
I dont have an intake yet but i was refering to something i read about some one having a whistle at idle... but i could be wrong it might have been because of the BPV.
Old Nov 9, 2009 | 04:23 PM
herbie hind's Avatar
herbie hind
mine no longer whistles....HAI RULES!!!
bahman
Feb 14, 2016 10:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Emnotek
Sep 29, 2015 07:37 AM
