Suspension Mini Madness Rear Upper Strut bushings (HELP!!)
Old Oct 3, 2009 | 11:47 AM
M3NTAL's Avatar
M3NTAL
I cannot get the top strut nut back on due to the lack of deflection. I can get them on if I remove one washer from the chain though, but that is not good.
Any tips on how to get these finished up?
Old Oct 3, 2009 | 11:55 AM
ron-s mini's Avatar
ron-s mini
Do not want to over simplify, but compress the springs. Put a jack under the assembly and lift slightly (safety first - be careful not to lift the car on the jack stands).
Or compress with a spring compressor.
Old Oct 3, 2009 | 01:43 PM
M3NTAL's Avatar
M3NTAL
Ron-S - thank you for the thought, but it is not limited by the spring. Even with the spring completely out of the equation they do not go on. I have cross coilovers and the hat stops where it is supposed to on the shaft.
The poly bushings just dont compress at all in order to catch a little bit of thread. The only thing I can think of is a specialized c-clamp.
Old Oct 3, 2009 | 01:57 PM
ron-s mini's Avatar
ron-s mini
Perhaps a picture could get a more experienced pro to chime in?
Old Oct 4, 2009 | 07:34 AM
Soulsword's Avatar
Soulsword
M3ntal,
Hope you got struts back together, but if not, is there anyway you have the very top concave washer backwards? the low spot should point down. Good install pdf here.
http://www.mini-mods.com.au/files/ho...ut_Install.pdf
BTW, I did install the MINI Maddness bushings myself without issues. I was using Koni FSD's with stock springs.
Old Oct 4, 2009 | 08:26 AM
ron-s mini's Avatar
ron-s mini
Nice write up.
Old Oct 4, 2009 | 10:10 AM
Soulsword's Avatar
Soulsword
Yes, that is a great write-up. I pulled it from this thead, but it is linked in others.
https://www.northamericanmotoring.co...tructions.html
Another great strut install is here:
https://www.northamericanmotoring.co...ll-how-to.html
Old Oct 4, 2009 | 10:24 AM
M3NTAL's Avatar
M3NTAL
Soulsword - thank you very much for the PDF. I had tried flipping the washers, but it didn't seem to help any.
Old Oct 4, 2009 | 04:07 PM
Soulsword's Avatar
Soulsword
Well that sucks.
Did you try putting the original bushings back on and did it fit? I don't recall the MM ones being anythicker or too tough to get to go on. The only thing I could think would be that the parts are some how out of order. #4, 6, 7 in the PDF of the strut assembly order if wrong might cause your issue. On page Ten #4 is shown how it should be with the strut up and #6 and 7 what you see should be facing down (referanced if it was on the car). Other than that is the strut(s) good? could it just be compessed and not comming back out?
Let us know what happens.
Good luck.
Old Oct 7, 2009 | 09:33 AM
OldRick's Avatar
OldRick
Perhaps you could ask Mini-Madness?
Old Oct 7, 2009 | 10:18 AM
Soulsword's Avatar
Soulsword
So, M3ntal any luck yet?
Old Oct 7, 2009 | 11:31 AM
M3NTAL's Avatar
M3NTAL
No luck - it just might be the design of the coilover. I had to press on the stock units to get some threads to show also.
Old Oct 7, 2009 | 12:04 PM
Soulsword's Avatar
Soulsword
OK, I just reread this thead. You are using cross coilovers? If the MM bushing can't go on wouldn't you be bottoming out all the time? Are you using the stock "bump stop" and is it cut down? Or am I missunderstanding your issue?
You can't assemble the strut with the MM bushings right?
Old Oct 7, 2009 | 12:40 PM
M3NTAL's Avatar
M3NTAL
The Cross setup does not use the factory bumpstops, but it does re-use the factory hat where the two bushings are at. The top of the strut passes through the bushings and is threaded where a nut goes on and holds it all together. There is another assembly below this that holds the spring together - it is completely independent (with or without spring in place it is still the same amount of area taken up)
You can see in that photo that the rear setup will not bolt to the car w/o the top hat. The top hat is added with some washers and a spacer and the bushings
Old Oct 7, 2009 | 01:32 PM
Soulsword's Avatar
Soulsword
Well if you have the bushings in the right order; one on either side of the top plate (big bushing on coilover spring perch, then top plate then smaller bushing) I can't see what else it would be but a function of the coilover top sping perch to end of strut shaft (just as you said)
Hold on, I have my old stock struts and can measure end shaft length. I know this won't take into account some of the other atttatched componants but might give an idea.
Old Oct 7, 2009 | 01:47 PM
Soulsword's Avatar
Soulsword
OK I've got 2 1/8 inches from what I whould call the shaft "stop" (where the shaft diameter gets bigger) to the end. If you have too much less that could be the issue.
Also you said if you removed a washer it would work. Did you mean the last one under the nut (concaved one), becuase if not I don't think anyother washer should be in the way.
Old Oct 7, 2009 | 02:05 PM
Soulsword's Avatar
Soulsword
So on this washer thought. Using this PDF:
page 10 (exploded view of strut ***'y) you are only using #4, 5, 6 ,7 ,8.
4 and 6 being MM's bushings. There is a washer IN #4 (don't know how important that is) so no distance lost there. the only washer left is the concaved one (#7) unless one has been suppled by cross for the strut nut, in which case I would not use it.
Good luck.
Old Oct 7, 2009 | 02:16 PM
M3NTAL's Avatar
M3NTAL
The cross setup has different washers - one under 4 and one above 6 and they are both flat (not concave).
The one under 4 is important because there is a spacer. #1,2,3 are all gone. The bumpstop is internal in the cross setup.
Old Oct 7, 2009 | 02:38 PM
Soulsword's Avatar
Soulsword
I can't see why one above #6 would be needed at all with the large concave one there, I would loose that. and maybe with just the concave one it would put a more pinpoint pressure on bushing easing installation. I don't understand about the one under #4; a spacer? is this necessary to keep top plate from hitting spring perch? If so maybe a mod on the spacer since the MM bushings will deflect less.
I need to go, but it sounds like you've done about all you can, did you contact who sold you the coilovers? Or as mentioned by someone else maybe
MM might have some insight.
And you know I can't belive no one else has been though this; doesn't anyone like the MM bushings, I really did like the extra feel. Almost like adding
a little more to the strut bar. the rear SEEMED more stable.
Again good luck
Old Oct 12, 2009 | 10:47 AM
Soulsword's Avatar
Soulsword
Hey M3ntal,
You ever get the MM bushings in, or did you just stay with the stockers?
And how do you like the Cross CO's in general? It was one I was considering
before I settled on the FSD's. I truely like the FSD's but wonder if a little stiffer would have been better.
Old Oct 12, 2009 | 11:33 AM
M3NTAL's Avatar
M3NTAL
I ended up with the stock bushings.
I really can't compare the cross setup to anything but stock. I do like them more than stock.
OctaneGuy would be a good guy to ask. I know he went from an aftermarket spring strut combo to the Cross setup.
Old Oct 12, 2009 | 09:48 PM
It Works's Avatar
It Works
If you don't get anywhere, take it to the shop I go to. Ping me if you've forgotten who/where it is.
Toolman
Jan 20, 2016 06:50 AM
minicoclub
Nov 11, 2015 07:25 AM
Mini'mon
Aug 26, 2015 01:02 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
