R50/53 nocking sound front passanger side
Old Sep 20, 2009 | 04:42 PM
minikania's Avatar
minikania
when turning right all the way also when hard brake and hard start off the line. also when i turn all the way it nocks onces in and nocks out its not constant
I'm thinking it may be the axel,
any thoughts????
Old Sep 20, 2009 | 04:59 PM
AutoXCooper.com's Avatar
AutoXCooper.com
How many miles and what year is the MINI? There's a few things that could be making the noise more info will help us help you.
Old Sep 20, 2009 | 06:03 PM
Montana Miniac's Avatar
Montana Miniac
You might check your motor mounts.
Old Sep 20, 2009 | 09:11 PM
desmo's Avatar
desmo
Knock when turning
Could be a torn upper strut mount. Open the hood and look down inside of the strut tower, it'll be pretty obvious if the rubber mount is torn.
I've got about 110,000 mile on my MCS and never had a problem with my CV joints but I have had one torn upper strut mount.
Good luck
Steve
Old Sep 20, 2009 | 09:36 PM
k-huevo's Avatar
k-huevo
Torn lower control arm bushing and/or failed ball joint.
Old Sep 21, 2009 | 04:37 AM
NightFlyR's Avatar
NightFlyR
If it sounds like 2 Cue ***** hitting each other it could be the Cv Joints
Old Sep 21, 2009 | 01:01 PM
minikania's Avatar
minikania
it’s a 2003 mini S with 75000km on it, I have kw's and alta end links... yesterday I took everything out to see if I could catch anything to the eye but I didn’t....
I’m leaning towards the cv joint reason why is when I had everything out everything just dropped to the floor.... but the cv joint had not rips in the rubber housing so I really don’t know,
as for the upper strut mount I doubt its that because it doesn’t make any sounds when I hit bumps.... like I said only rights turns pulled all the way and now when hard brake and start
Old Sep 21, 2009 | 06:06 PM
AutoXCooper.com
Thanks for the details. Have you checked the front control arm rear bushings?
Old Sep 22, 2009 | 07:07 PM
minikania's Avatar
minikania
ok well i do have some questions, what exactly is the differance between the power flex bushing and the psrs...
Old Sep 22, 2009 | 08:26 PM
AutoXCooper.com
Many things. But before we cross that bridge let's make sure that your bushings are bad. If they are then we can talk about which is best for you.
Old Sep 22, 2009 | 10:23 PM
MLPearson79's Avatar
MLPearson79
I had knocks with hard turns (wheel turned all the way). It was the joint in the steering column and both racks were replaced.
Old Sep 22, 2009 | 10:39 PM
minikania's Avatar
minikania
[FONT='Verdana','sans-serif']I’ve read the symptoms of a bad bushing and that doesn’t really sound like the problem that I have..... My wheel doesn’t move back and forth and no vibration on hard brake.....so I really don’t know as of now it’s could be the axel vc, bushing or a torn upper strut mount[/FONT]
boostedhaze
Jan 2, 2018 07:26 PM
cm.d
Aug 19, 2015 08:51 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
