Dynoed 230whp GP in TURKEY
Old Sep 12, 2009 | 11:02 AM
grkm's Avatar
grkm
Greetings from Turkey again
My friend's GP 0638
CP pistons
Pauter Rods
Dr. Schrick Cam
Ported Head
Ported Induction Manifold
Supersprint Headers(should be replaced with custom)
Alta V2 IC
Alta %17 sc pulley ( oem %11 )
Ati %3 dampered crank pulley
HKS F-CON Ecu tuned by Oz aka Dr. ECU
3.5bar AEM Map sensor
GM Air temp sensor
Msd Coil
Oem Throttle body
Oem 380cc injectors
Oem Header-back exhaust
Pump Gas less than 91ron in Turkey :(
rev limitor was on 7240rpm
temp was 27Celsius (80 Fahrenheit)
running on 18,5 psi
after tb , header + exhaust and methanol will be dynoed again
we would like to see more than 250whp
Old Sep 13, 2009 | 05:57 PM
D-MAN's Avatar
D-MAN
Nice numbers
What are the AF ratios like?
You got some ***** running a 17+3 combo
Old Sep 18, 2009 | 07:44 AM
grkm's Avatar
grkm
I'm sorry, I was wrong on specs. It was running on 14psi with OEM SC Pulley.
AFratio was around 12.8-14 on full throttle on 14psi. I don't know maybe it would be better on lean on 18psi.
Peak EGT is 810-820 Celcius Degrees end side of the Header w/out Meth.
Old Sep 18, 2009 | 04:52 PM
Luys's Avatar
Luys
nice numbers I think it is M7 Cosworth head, am I right?
Old Sep 19, 2009 | 02:08 AM
grkm's Avatar
grkm
It just modificated oem JCW head , you know its not so good for our cars, causes high temp. on pistons , constrains air flow etc etc...
I think now it's as good as RMW's or Cosworth's head, you see the power band and figures on stock boost.
Old Sep 29, 2009 | 03:52 PM
grkm's Avatar
grkm
running on 15psi
http://videos.streetfire.net/video/m...684_709534.htm
after new header & exhaust , meth. and tune I will share new vid.
NYMADMINI
Dec 14, 2016 02:33 PM
slash695
Apr 26, 2016 06:27 AM
USA-RET
Nov 9, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
