R56 Hot air venting
Old Sep 8, 2009 | 07:33 PM
Gerarddm's Avatar
Gerarddm
Hot air venting
So I've read the threads concerning opening up the hood scoop to help control under-hood temps, but has anybody ever tried making the side scuttles operational, thereby venting hot air out the sides? Inquiring mind wants to know-
Old Sep 8, 2009 | 07:42 PM
Shoof's Avatar
Shoof
IMO, the vents are WAY too small to net any sort of difference in underhood temps..
Old Sep 8, 2009 | 07:53 PM
Dwight Walhood's Avatar
Dwight Walhood
Not sure what you mean by side scuttles, but getting rid of heat is no problem while the car is moving. It vents out the bottom. When stopped, it's a whole different story. Any additional venting would need to be as high as possible to allow convection currents to push the heat out. Opening up the scoop will help, but to me the real culprit is the cowl molding. It's completely closed off! Any ideas?
Old Sep 8, 2009 | 08:04 PM
Shoof's Avatar
Shoof
Side scuttles:
Old Sep 8, 2009 | 08:49 PM
Dwight Walhood
Originally Posted by Shoof
Side scuttles:
Thanks Shoof, now I know what scuttles are.
Old Sep 8, 2009 | 10:29 PM
Benibiker's Avatar
Benibiker
That whole area just before the scuttle where the hood meets the scuttle is already open. The problem is the radiated heat from the turbo that sits just under the cheap plastic scoop. Key word being radiated...
Old Sep 9, 2009 | 07:18 AM
Dwight Walhood
Cold(er) Air Works!
Radiated heat indeed! The only place on the hood I was getting those high temps (250F.) with my IR/Laser gun was directly over the turbo. The heat shield cured that. For more info on how that scoop came to be, check MINI2.com in GB. BTW, radiated heat is why I thermo-wrapped the air intake tube. It worked. Also, that fancy temp gun can be had at Harbor Freight for $40!
Old Sep 9, 2009 | 10:38 AM
eR1c's Avatar
eR1c
M7 Heat shield + CF hood scoop ...works awesome! -no hot hood!!
Sep 3, 2015 01:45 PM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
