Interior/Exterior dome light?
dome light?
--Ive posted this already in stock problems but no one has been able to help me so i'd figure i would try my luck here.
I replaced the Dome lights with a 39mm LED festoon. it was kind of to big so i bent the two little metal connectors to fit it. It worked fine but last night i noticed the light flickering. I went to go adjust it and one of hte metal arms snapped.
What are those metal connectors called and where could i pick one up..im assuming its a very common part at stores like home depot.
You may have to just solder it back together. If the LED dome light you got doesn't fit right try our WMW dome light it works great.
http://www.waymotorworks.com/product...3&cat=0&page=1
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
When connecting LED lights instead of the regular tungsten bulbs, I learned that the MINI system doesn't like the very, very low current draw and therefore causes the LEDs to flicker. I did a thread several years ago when putting LED strips in the boot. I had to add a resistor, about 1000 ohms I think to bring the total resistance up to something the MINI computer liked.
Just a suggestion.
YD
Just a suggestion.
YD
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
