R56 getting mini dynoed.
Old Sep 1, 2009 | 01:36 PM
AkFarina's Avatar
AkFarina
Hay im getting the mini dynoed. should i do this with sport on and dsc off and in what gear?
Old Sep 1, 2009 | 02:32 PM
white rocket's Avatar
white rocket
will you be driving while the Mini is on the rollers? My guess would be a 5th gear pull to redline with TC off.
I'm curious about others opinions though
Old Sep 1, 2009 | 02:47 PM
malteseracer's Avatar
malteseracer
This may be me being dumb but having no experience with dynos...do the rollers make it possible to make a 5th gear pull without rapeing your clutch? I barely like to set off in second let alone fifth
Old Sep 1, 2009 | 03:25 PM
Bigshot's Avatar
Bigshot
Usually a 4th gear pull is used and you shouldn't be doing it. The shop should be doing the "driving".
Old Sep 1, 2009 | 06:27 PM
ianskate's Avatar
ianskate
On a semi-related note, if you haven't seen Garage419, they did a test of two dyno devices, with the Garage 419 Mini. Kind of cool.
http://www.vodcars.com/garage419/episode/419_20080807
Old Sep 1, 2009 | 06:50 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Wait wait wait! It dyno'd (on a dyno machine) at 165.5 HP. When MINI says 172 HP (and MINI is known to understate their numbers.)
Old Sep 1, 2009 | 06:57 PM
ianskate's Avatar
ianskate
*shrug* Don't ask me, I just thought it'd be an interesting watch
Old Sep 2, 2009 | 12:08 AM
Ottoman_FD3S's Avatar
Ottoman_FD3S
LOL
no man u don't start from 5th
u start from first.. and go through the gearbox till u reach 5th
u then hit record and mash the pedal.. from approx 1,500-2,000 RPM till redline..
then u let go and let the engine speed fall... when it reaches near idle speeds u push in the clutch
as for the others asking about the gear
no matter what Car it is.. You always choose the gear that is closest to 1:1 ratio
u don't want the torque multipliying affect of the tranny effecting readings..
Old Sep 2, 2009 | 02:21 AM
malteseracer
Originally Posted by Ottoman_FD3S
LOL
Ah see I wouldn't have known that.
Old Sep 2, 2009 | 07:03 AM
Bigshot's Avatar
Bigshot
LOL
Depends on the dyno used.
Old Sep 2, 2009 | 07:05 AM
Bigshot's Avatar
Bigshot
Dynos are notorious for not giving consistent results from different shops. As long as you use the same dyno each time you do a test, the results will give you the deltas. That wil tell you how well your mods are doing.
Old Sep 2, 2009 | 09:36 AM
AkFarina's Avatar
AkFarina
what is the 1:1 on our care
Old Sep 2, 2009 | 10:11 AM
OPC's Avatar
OPC
RATTUS Deserticus
Brake Horse Power (BHP) vs Wheel Horse Power (wHP) at the wheels. MINI publishes engine output at the crank without loss due to transfer (gearbox, water pump, etc). Wheel output is always less. FYI, conversation with Jan at RMW indicated that all the bone-stock R56MCSs he has dyno'd were very consistent at ~164hp at the wheels.
Old Sep 2, 2009 | 11:22 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
5th. 5th gear is 1:0.949
Old Sep 2, 2009 | 06:48 PM
AkFarina's Avatar
AkFarina
my Mini = a Joke
Alta CAI, straight pipe from dp back.
4th gear
sport on
dsc off
dynojet winpep 7
run type: RO, 79 f, 30.00 in-HG, humidity 27%, SAE0.97
Old Sep 3, 2009 | 07:06 AM
Bigshot's Avatar
Bigshot
Sounds about right to me, but then again there are a lot of differences in the dynos too. Just do some mods and take it back to the same place and check the delta's.
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
