R50/53 Key FOB?
Old Aug 23, 2009 | 01:00 PM
tonka's Avatar
tonka
Key FOB?
I just purchased a 05 MCS and was trying to program the key FOB. I found a wiki that said hold down the unlock and press the lock 3 x on the 3rd time release the unlock. Now i cannot even lock it with the FOB! How do I program the FOB again?
Thanks!
Brian
Old Aug 23, 2009 | 10:15 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I thought the only way was to have the dealer use their machines on it.
Old Aug 24, 2009 | 06:34 AM
Winchm60's Avatar
Winchm60
Did you stick the key in the "accessory" position of your car for a few seconds first?
Then take it out and try again.
Old Aug 24, 2009 | 08:01 AM
AK.JCW's Avatar
AK.JCW
I'm with nabeshin on that... I thought you could only "program" at the dealer?
I found the wiki link but it does not explain what you are "programming" you fob to.. the car? or features on the car?
Old Aug 24, 2009 | 10:52 AM
rnelsonee1's Avatar
rnelsonee1
I had to do something with my keys after the fob's battery died - I replaced it, and it didn't unlock my car until I futzed with it for 10 minutes inside my car, so maybe that's what the person is asking about...
(I don't remember what I had to do - I kept restarting the car and changing the key position until it worked)
Old Aug 24, 2009 | 12:22 PM
rgc0233's Avatar
rgc0233
Try the BMW method:
1. close all doors and have all keys available
2. using key no.1 turn ignition switch on. within 5 seconds switch ignition off and remove key from ignition
3. within 30 seconds of turning switch off, press and hold unlock button
4. while continuing to hold unlock button, quickly press and release lock button three times within 10 seconds
5. release unlock button
6. if initialization was successful, all locks will be activated and released in rapid succession. if the led continues to flash or if the locking system fails to respond, repeat the procedure.
Old Aug 24, 2009 | 05:30 PM
tonka's Avatar
tonka
Originally Posted by rgc0233
Try the BMW method:
That is exactly what I was needing! Going to go try that now. Quite frustrating to have the FOB's not working. Thanks for all the replies and I will let you know if it defaults it back.
THANKS!!
Old Aug 24, 2009 | 06:02 PM
tonka's Avatar
tonka
That did it! My second key did not work after tying the same procedure, but I think it may need a charging. Thanks again to all!
JamesDeBart
Apr 16, 2016 05:00 PM
joedotmac
Oct 23, 2015 11:32 AM
newminijcw
Oct 21, 2015 02:37 PM
jennster
Sep 28, 2015 06:19 PM
