R50/53 05 MCSa with broken dipstick
Old Aug 21, 2009 | 03:27 PM
Scanner's Avatar
Scanner
any ideas on how to get it out....only 4 inches left on the handle, but don't see it in the tube...could it have migrated into the oilpan ? any help would be greatly appreciated----scanner
Old Aug 22, 2009 | 01:42 AM
Cadenza's Avatar
Cadenza
You have to find out if the tube is removable. If yes, you're in luck. If no, I think the oil pan has to be dropped.
Old Aug 22, 2009 | 06:50 AM
Speedee's Avatar
Speedee
Yes... The tube is removable.. It has an "O" ring, sealing it to the engine block... I know, because mine was leaking. Tough job removing the tube, though... Gotta take apart most of the front end just to get to it.
Old Aug 22, 2009 | 10:31 AM
Cadenza's Avatar
Cadenza
Someone should start a list of what problems/repairs require the removal of the front end.
Old Aug 23, 2009 | 12:21 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Mine broke like at 3 or 4 inches in there, I took it out with a 4 Prong Tool Claw. You can pick one up at any parts store or tool store for like $5 bucks. You have to flatten the prongs simply by smashing them to fit down oil plug. Then put it down and pull on the spring handle to grab broken piece.
4 Prong Tool Claw: http://www.amazon.com/36-Pro-Claw-Pi.../dp/B000NPR3WU
Old Aug 23, 2009 | 01:50 PM
Cadenza's Avatar
Cadenza
This is a really cool tool. Definitely better than pulling the front end apart.
Old Aug 24, 2009 | 01:25 PM
Scanner's Avatar
Scanner
thanks for all the info...will try the claw technique...just ordered one that's fully flexible
Old Aug 24, 2009 | 06:41 PM
howsoonisnow1985
AutoZone has a 16 inch one for 4.99.
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Mar 3, 2017 06:29 AM
Fordgt4
Oct 10, 2015 10:42 AM
B1mm3r101
Oct 1, 2015 06:22 AM
daviday
Sep 25, 2015 01:31 AM
