R50/53 miata wheels on MINI=problem on wheel bolts
Old Aug 14, 2009 | 07:14 PM
chilimac's Avatar
chilimac
I bought a set of team dynamics wheels from a MIata owner. They have the same offset and bolt pattern but the lug nut holes are smaller. The factory bolt (m12x1.5) will not seat on the wheels.
Is it possible to get m12 bolts with smaller heads or do I need to get the wheels machined to accomodate MINI bolts?
Old Aug 14, 2009 | 07:19 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Might need "tuner" lug bolts. I had the same problem when I put a set of MINI wheels on my Mazda MX3.
Old Aug 14, 2009 | 07:33 PM
chilimac's Avatar
chilimac
can you tell me more about the tuner bolts? I also want to switch to studs. I got a stud kit but the nuts do not provide enough clearance for a socket to tighten things up Is it possible to get "tuner' lug nuts?
Old Aug 17, 2009 | 08:59 AM
ALTA_Jarid's Avatar
ALTA_Jarid
Sure is...just did a quick google search on "tuner lug nuts"
ttp://www.summitracing.com/search/Brand/Gorilla-Automotive/Product-Line/Gorilla-Small-Diameter-Tuner-Lug-Nuts/?autoview=SKU
SosoMINI
Nov 22, 2015 03:17 PM
nomar116
Aug 12, 2015 05:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
