Noise / ticking from transmission
Old Jul 22, 2009 | 09:15 PM
b_artman's Avatar
b_artman
Hi guys.. I just picked up an 05 MCS 6speed manual - stock no mods, 38,000kms. I have driven the car for just one fill up and have noticed a noise that is worrying me!
When the car is in neutral there is a ticking type noise coming from the tranmission. i can hear it from inside the car very clearly and the best way i can describe it is that it is similar to when you put a playing card into a spinning bike wheels.
When i press the clutch pedal the noise goes away and will come back when i release the pedal. When i press the throttle in neutral the ticking noise increases in speed. i cannot tell if it is making the noise as i drive the car because the engine/exhaust noise drowns out the ticking. regardless if the car is warmed up (1 hour driving) or not, the noise always returns when the car is in neutral.
has anyone here experienced such a thing in their car and if so what was the prognosis?
Thanks!
Old Jul 23, 2009 | 04:19 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Does it sorta make the engine sound like a diesel motor ?
If so I have heard this in r53's before and it is even more noticable in those MINI's which have had a clutch / flywheel upgrade.
Old Jul 23, 2009 | 02:57 PM
b_artman's Avatar
b_artman
it sounds like a ticking.. it speeds up when pressing the throttle. the car is stock, so no flywheel upgrade.. any ideas?
Old Jul 23, 2009 | 11:46 PM
Some Guy's Avatar
Some Guy
It is just gearbox/clutch chatter, it is somewhat normal and completely harmless. Anyway, the fix involves pulling the transmission and replacing the dual mass flywheel with a new one, which isnt really worth it to just fix a noise IMO.
lweaver
Sep 17, 2024 08:22 AM
Supertractor3
Apr 7, 2017 11:16 AM
thadscottmoore
Sep 25, 2015 10:07 AM
Sailorlite
Sep 4, 2015 07:03 PM
