R50/53 New lights/coming of age
Old Jul 20, 2009 | 07:39 PM
teamrubixcube's Avatar
teamrubixcube
Hello all, I JUST got my new halos in and adjusted (the best I can do for tonight) so I naturally took some pictures to post up here. I figured that since I'm new as well I'll just post some old ones too so you can see how the mini has transformed in just the 5 months I've had it. Enjoy!
Attached Thumbnails New lights/coming of age-dsc_0055.jpg   New lights/coming of age-dsc_0014.jpg   New lights/coming of age-dsc_0163.jpg
Old Jul 20, 2009 | 07:49 PM
teamrubixcube
Oh, and for anybody interested in getting those aftermarket lights (I've seen a couple threads about them on here), here are some more pictures dedicated purely to that. From just my driving around tonight, I can honestly say they are better than stock, not by much, but are a huge pain to level. As you can see in the picture I still have some work to do with the cutoff.
Attached Thumbnails New lights/coming of age-dsc_0006.jpg   New lights/coming of age-dsc_0017.jpg   New lights/coming of age-dsc_0020.jpg
Old Jul 20, 2009 | 10:56 PM
beyouandbetrue's Avatar
beyouandbetrue
how easy was the install and was it manly plug and play? looks good by the way
Old Jul 21, 2009 | 08:13 AM
teamrubixcube
The install was very easy I thought. The rings could have a better fit but I can't complain. Not noticeable at all unless you REALLY look for it. As for the wiring, the highs and lows are just plug and play, just need some leveling. As for the halos, those were a little tricky tying them in with the running lights but not bad at all with the correct connector plugs and splicers. If you want I'll take some pictures and post em up....if it ever stops raining in new england.....
Old Jul 21, 2009 | 01:01 PM
beyouandbetrue
that would be awesome i really want to buy some new headlights soon thanks agine and i hope it stops raining sooon
Old Jul 21, 2009 | 02:07 PM
AggieMini11's Avatar
AggieMini11
Where did you get them? I found some like these on Ebay. I was really thinking of buying them and im glad to see your review!
Old Jul 22, 2009 | 10:45 AM
teamrubixcube
Alright, so the weather is finally nice and I got some pictures that will hopefully help. AggieMini, I got mine off of Ebay as well as they are far cheaper than Moss Mini who also sell the same thing. The high and lows are just plug and play with the big plug you'll see in the picture. I tried to show how I wired down to the running lights the best to my ability. I used some wiring splicers with plugs so if I ever want to change back to stock all I need to do is pull out the plugs and leave the female connector in place; plus it makes the wiring wayyy faster/easier. Also, to be honest, the lights do look a bit ricey with the globes being purpleish if you're above the light cut, but in my opinion it looks pretty cool Hope this helps!
Attached Thumbnails New lights/coming of age-dsc_0012.jpg   New lights/coming of age-dsc_0008.jpg   New lights/coming of age-dsc_0005.jpg
Old Jul 22, 2009 | 12:48 PM
beyouandbetrue
teamrubixcube thanks a bunch for the pic's
Old Jul 22, 2009 | 03:32 PM
DixonL2's Avatar
DixonL2
WRAP THOSE WIRES!!!! You've got voltage flying around in there... and a short means a brief trip with no lights - and you know that'll happen at highway speeds. Scotch 33+ electrical tape is gear, holds up to underhood temps, doesn't get that black sticky residue, and you can over-wrap those wires for $3.50. Also hoping you've fused the 12v+ wiring. If that's duct (or worse, packaging) tape holding your wiring in place, please over-wrap those wires with 33+ and secure physically against them blowing around, detaching, or otherwise causing problems!
If you've done all that and had left everything exposed for the pictures, completely understand and apologies for any inconvenience....
The lights look great though, and glad they're working better than OE.
Old Jul 22, 2009 | 05:30 PM
teamrubixcube
Don't worry! It's all wrapped up like that. In the pictures I took tape off of the connections to show the connectors I used, but everything is secure in there and I actually used plastic zip-ties to run them along other lines already secured down as well. But good call about that! I can't imagine much worse than traveling at highway speeds and having the lights cut out on you...granted it would only be the halos which are just for show
Old Jul 22, 2009 | 06:37 PM
AggieMini11
Thanks for all the pics and tips! When I get them, I will probably be PMing you for some advise.
Old Jul 22, 2009 | 09:38 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Now you can get the angel eye turn signals to go with them.
http://www.waymotorworks.com/product...cat=322&page=1
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jul 23, 2009 | 06:22 AM
DixonL2's Avatar
DixonL2
rubix, glad you have that under control. The lights do look really good...
FatherG
Oct 3, 2015 05:06 PM
Minnie.the.Moocher
Sep 24, 2015 08:04 AM
Accessory Products
Sep 10, 2015 11:38 AM
Suspension Products
Sep 3, 2015 09:41 AM
