R56 front brake pads gone in 20k?
Old Jul 13, 2009 | 07:32 PM
maloosheck's Avatar
maloosheck
The front brake pads in my wife's MCS are almost gone after less than 20k miles.
Is this normal?
Old Jul 13, 2009 | 07:48 PM
ricbow's Avatar
ricbow
Is this normal?
yes , wait for sensor light. then call and make appointment at your dealer (service agreement means its free)
Benibiker's Avatar
Benibiker
Just wait until they tell you the disks are almost gone too! $$$$$
Old Jul 13, 2009 | 07:53 PM
maloosheck's Avatar
maloosheck
Wait, the brake pad replacement is free?
Old Jul 13, 2009 | 08:20 PM
old81's Avatar
old81
M6
If you have the MINI warranty, yes. pads and rotors covered for free in the first 36K. If you have extended, covered too.
Old Jul 13, 2009 | 08:49 PM
Btwyx's Avatar
Btwyx
Is this normal?
It depends how enthusiastic you are. I got the front brakes done at 16k on the MC and 8500 on the MCS. Though that was helped by some track days particularly in the MCS, one of the track days ran 7k off the brake service indicator. The dealer did both services for free under the maintenance warranty.
The MINI spec is the pad should be replaced at 3mm, but the dealer would do the brakes if the indicator was under 4000 miles.
Old Jul 13, 2009 | 09:08 PM
drewstermalloy's Avatar
drewstermalloy
So there's a sensor light that goes off for the brakes?
Old Jul 13, 2009 | 09:10 PM
Oxybluecoop's Avatar
Oxybluecoop
Yep
Old Jul 13, 2009 | 09:17 PM
carsncars's Avatar
carsncars
...if the OP is in the US. No go for Canada... this is "North American" Motoring, after all.
Old Jul 13, 2009 | 09:29 PM
drewstermalloy
Didn't know we got new brake pads under warranty. Sounds pretty good to me.
Old Jul 14, 2009 | 01:14 AM
Robin Casady's Avatar
Robin Casady
My understanding is that it you are supposed to replace rotors on MINIs when you replace the pads.
Old Jul 14, 2009 | 03:51 AM
mini cooper mini's Avatar
mini cooper mini
That was what i understood as well, replace rotors with pads, but that seems dumb. Most cars its 3 to 1. Three sets of pads for every one rotor change, on average.
Old Jul 14, 2009 | 03:54 AM
glhboy's Avatar
glhboy
how do you check how many miles left on obc?
Old Jul 14, 2009 | 09:58 AM
RaceTripper's Avatar
RaceTripper
The rotors are imprinted with a minimum thickness. When replacing pads replace the rotors if they don't have enough thickness anymore, but you may not need to.
The OEM pads are softer than many aftermarket ones (which is why they dust like crazy), so they may wear faster than the rotors. If you are getting it all done under the free maintenance, then yes, take the rotors. If you're paying for it, do the rotors if needed, but not necessarily when replacing pads.
Old Jul 14, 2009 | 10:15 AM
RJKimbell's Avatar
RJKimbell
Something else to discuss with my Dealer. I will be coming up on 20K in 1,500 miles. I will also be replacing my Runflats at that time too.
Old Jul 14, 2009 | 10:25 AM
AutoXCooper.com's Avatar
AutoXCooper.com
"most cars" yes, but not a MINI. You might be lucky to get 2 to 1, but I've never seen anyone getting 3 to 1 on a MINI.
After the free pads and rotor service is done at the dealer there are many aftermarket pads and rotors that will give you longer life on the street*.
* the above statement doesn't apply to pads and or rotors used for track events.
Old Jul 14, 2009 | 11:09 AM
RaceTripper
Are there any replacement rotors yet for the factory JCW front 4-pot Brembo brakes?
Old Jul 14, 2009 | 11:49 AM
AutoXCooper.com
not that I have found and given the time it took to get the R53 JCW/R56S rotors in the aftermarket I wouldn't plan of seeing any soon. But I can get you the pads.
Old Jul 14, 2009 | 12:04 PM
RaceTripper
Yes, I have your pads, or what's left of them.
Yeah, the official replacement rotor is the vented/slotted ones for about $150/each. About about 12K miles with one track weekend into the original ones. They look good for now.
W0TM8
Dec 19, 2019 07:50 AM
bjcarter2
Aug 31, 2015 04:03 PM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
