Something is killing my ballast
Old Jul 10, 2009 | 02:09 PM
derekj4's Avatar
derekj4
I was having problems with my Xenons flickering and then going out. So, I replaced both bulbs and the driver side ballast. Worked perfectly for about 2 months. Now the driver side light is out again.
Anyone know what upstream of the ballast might be causing it?
TIA,
Derek
'03 MCS
Old Jul 10, 2009 | 02:52 PM
Yo'sDad's Avatar
Yo'sDad
Check all connections and electrical plugs for cleanliness, no corrosion and tightness.
YD
Old Jul 10, 2009 | 05:15 PM
herbie hind's Avatar
herbie hind
+1 on the corrosion. check the ground connections at front of frame rails in engine bay; all brown wires , guess these areas are prone to corrosion due to their local .
Old Jul 10, 2009 | 10:03 PM
lovethecorners's Avatar
lovethecorners
Sorry to hear about your issues. I had poor luck with my 2003 MCS Xenons whereas the passenger-side xenon would take multiple attempts to ignite and I was able to figure out it wasn't the bulb or ballast. Unfortunately I had to replace the control module and afterwards it worked without issue until I sold the car. Expensive, but in my situation it's what solved it. I can't remember how easy it is to remove the control module from it's housing (I think it's well sealed) to swap between driver and passenger side for troubleshooting, but I'd try that if possible after examining the ground and electrics. Good luck.
krohm
Sep 28, 2015 12:16 PM
trexcookie
Sep 20, 2015 03:14 PM
shahriar35
Sep 12, 2015 08:31 PM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
