Drivetrain Damaged Cylinder Head
Old Jul 1, 2009 | 05:47 PM
resipsamcs's Avatar
resipsamcs
I have a cylinder head which was removed from my car at approximately 75,000 miles. It has slight/moderate warping. Is the head worth anything other than scrap?
Old Jul 1, 2009 | 08:07 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
It could be reground and used with a slightly thicker head gasket and be fine, some scientists believe.
Old Jul 1, 2009 | 08:13 PM
Dr Obnxs's Avatar
Dr Obnxs
The head is aluminum...
so it's milled, not ground. But weather it can be fixed depends on the degree of warpage. If it's too much, then the combustion chamber volume varies too much.....
Anyway, a good automotive machine shop should be able to evaluate it. If it's toast, you can always just cut it with a band saw to see the intake and exhaust port shapes and make some door stops.
Matt
Old Jul 1, 2009 | 08:29 PM
daemon2's Avatar
daemon2
Aluminum is currently worth .73/lb at the scrap yard.
Old Jul 1, 2009 | 10:02 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
There is a difference between milled and ground?
Old Jul 1, 2009 | 10:18 PM
Dr Obnxs's Avatar
Dr Obnxs
Yes...
grinding uses an abrasive wheel, and aluminum plugs it up and makes a mess. A head is typically milled with a fly cutter (like a lathe bit) that cuts the surface with a sharp edge.
There is something done with ferrous metals called "surface grinding" that can make very, very flat surfaces. This uses a grinding wheel and a table that goes back and forth underneeth it.
Matt
Old Jul 2, 2009 | 05:15 AM
onasled's Avatar
onasled
Matt
Haaaa, .... I'm thinking that you have Mini head door stops in your home.
Old Jul 2, 2009 | 07:57 AM
Thumper460's Avatar
Thumper460
Zackley.. a good machine shop will /can make the decision on the repair!! Give one a call if you havent all ready!! Yes??
Just me............................
Thumper
Old Jul 2, 2009 | 09:45 AM
Dr Obnxs's Avatar
Dr Obnxs
Nope...
I've been lucky twice. With an old Fiat I bought with a warped head it could be fixed, and when my Mini overheated and blew a head gasket I escaped warpage. I've just always liked the cut heads I saw in autoshop and in a bunch of shops I've been to.
Matt
Old Jul 2, 2009 | 07:15 PM
resipsamcs's Avatar
resipsamcs
Thanks for the responses.
Old Jul 4, 2009 | 10:44 AM
El_Griton's Avatar
El_Griton
oh come on guys you can get more creative then door stops. Im thinking im going to use my old head as a table some how.
Old Jul 4, 2009 | 12:25 PM
Dr Obnxs's Avatar
Dr Obnxs
A very small table...
Top Gear has a glass table on top of a V8 block....
You could put a light in each valve hole and make a wicked desk lamp though!
Matt
Old Jul 5, 2009 | 05:10 AM
stevecars60's Avatar
stevecars60
With a bunch of well placed magnets = the ultimate refrigerator door magnet & who has 1 of those?
UncDeo
Nov 4, 2019 04:08 AM
Manny_cooper
Sep 4, 2015 08:28 AM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 09:05 AM
