Advice on brake pads
Hi,
well, I'm having a little problem right now. I just pasted my 36,000 miles so I have no more maintenance. My light for my brakes just come on. I'm plaining of doing the job myself. I have the brake pads already. but I need step by step instruction. If you know how to do it exactly can you show me. can you make a video on youtube.com or respond to this. Also can you tell me or show me the tools you need. Thank you.
Front:
https://www.northamericanmotoring.co...beginners.html
Rear:
https://www.northamericanmotoring.co...tml#post550345
If your light came on, you'll also need at least one replacement sensor.
Rear:
craftsman,
The sensors are about $20 each and there are two of them on the automobile. One sensor on a front wheel and one sensor on a rear wheel. Hopefully, you will only need one. If you don't want to replace the sensor, you can make sure its electrical circuit is open and physically tie it out of the way or remove it at the lead connection. You don't really need a little light to tell you when the pads are worn out.
By the way, it is good you are doing this work yourself. It is not difficult and you can save a nice chunk of dough
Blimey,
thanks for providing the links for craftsman
Blimey,
Correct - except for the light to go off, the circuit needs to be *closed* - not open - so you can cut off the sensor head and twist the wires together - but, as has been said, then you lose the functionality of the brake pad sensor and must rely on checking them "the old fashioned way" (which I do).
Put this website on your favorites. It is full of how to's for just about everything MINI related including the pages suggested by Paul.
http://soopercooperinfo.com/
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 25, 2015 09:18 AM
