R50/53 Occasional warning lights coming on
Old Jun 23, 2009 | 10:26 AM
jpelaston's Avatar
jpelaston
as the title says, I have a couple lights that occasionally come on. it is the tire pressure light and the traction control light.. twice now in three days they have both came on at the same time and stayed on.
Both times I have stopped the car and shut it off and restarted and they have went off...
Any ideas as to what is causing this?
Thanks!
Old Jun 23, 2009 | 10:44 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Happening when you're just driving along in a straight line? Or when cornering?
If just when driving - then you may have a wheel speed sensor going out - or something else. Would be interesting to have someone scan for codes when the lights are on... depending on how persistent the data is, they may need to do it before you turn the car off - and would probably need a scanner that can see the BMW-specific systems to get anything useful...
Old Jun 23, 2009 | 10:59 AM
jpelaston's Avatar
jpelaston
They come on upon starting the car. I just shut the car off and restart.. The first time they didn't go off so I started to pull away and they went off. the second time they went off instantly after restarting.
I'm not too worried about it unless it becomes a recurring problem.
Old Jun 23, 2009 | 01:16 PM
minintrigue's Avatar
minintrigue
Wheel speed sensor - see here:
https://www.northamericanmotoring.co...-pressure.html
bneer
Jul 15, 2019 04:41 PM
Teh
Jun 13, 2018 02:59 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
