Wont accelerate over 4000rpm
Old Jun 9, 2009 | 01:10 PM
JohnnyVillan's Avatar
JohnnyVillan
First of all, my car is a 05 MCa
OK heres the deal
My cooling fan burned out a few days ago. The replacement from RockAuto arrived today (the website had the part number for both the pre and post 03 fan but the description says its the post 03)
I saw other people had problems putting rockauto's fan in a 02 but not in an 03+
So the new fan is in and spinning but when I rev or drive, I cant pass 4000rpms. I know there are 2 speeds for the fan but could the high speed fan not kicking in prevent the car from accelerating?
If that is the case, what do I do to fix it? A friend suggested either splicing the old relay into the new unit, or putting the new fan and motor on the old unit but electrical stuff like that intimidates me and I really dont think I can do it.
Also, my bumper cover and aluminum bumper are off the car. Could this have anything to do with the problem? (does the car know the bumper isnt on because the lights arent plugged in?
I need help bad! I cant go to work until my car is fixed! No work = no money.
Old Jun 9, 2009 | 01:23 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Is your car in "LIMP" mode or something ?
Old Jun 9, 2009 | 01:29 PM
JohnnyVillan
^^Whats that?
Old Jun 9, 2009 | 01:52 PM
JohnnyVillan
OK I did some research on limp mode
Will the car go into Limp Mode if the front bumper is off?
I think that even if the high speed fan wasnt kicking on, it would still accelerate. I managed to drive home normally after my old fan burned out completely.
Old Jun 9, 2009 | 04:36 PM
JohnnyVillan
I really need more help with this....
Old Jun 9, 2009 | 05:07 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Is your temperature sensor plugged in? It's attached to the bumper behind the lower grille usually - if it's unplugged, the ECU won't know the ambient temp and will do funky things like this.
Old Jun 9, 2009 | 05:13 PM
JohnnyVillan
^^Yea its plugged it. I even unplugged it and plugged it back in to make sure that wasnt it.
I reset the ECU too but still nothing
randeez
Oct 5, 2015 09:23 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
thadscottmoore
Sep 25, 2015 10:07 AM
gzaos
Sep 14, 2015 04:21 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
