Run flat wheels and tires
Old May 17, 2009 | 07:17 AM
jennkj62's Avatar
jennkj62
I am looking to get some new tires and rims. I currently have the stock rims and am looking at the Konig K-Tune 17x7 wheels. I'm not sure if I can put run flat tires on these rims. Any thoughts? Also, if I go with non run flat tires and rims, how will that affect the sensors on my 06 Mini S? Thanks
Old May 17, 2009 | 08:04 AM
JAB 67's Avatar
JAB 67
'06 does not have sensors. And why would you buy new wheels and then put run-flats on them?
Old May 17, 2009 | 11:44 AM
jennkj62's Avatar
jennkj62
I do have a light on the dash for low tire psi. My question was, if I want to stay with the run flat tires and upgrade the rims, can I buy any wheel or are there run flat specific rims and how this would affect the sensor?
Old May 17, 2009 | 12:30 PM
JAB 67's Avatar
JAB 67
Low tire pressure is a function of differences in the rotational speeds of all wheels as detected by the electronic gizmo connected to the ABS sensors, not sensors in each wheel. That feature does not appear until the 2007 model year.
Old May 17, 2009 | 12:44 PM
jennkj62's Avatar
jennkj62
Thanks for the info. Do you know if a run flat tire will be compatible with a standard rim?
Powershift
Aug 16, 2015 05:14 PM
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 9, 2015 09:42 AM
