Electrical Rear Fog Ohm Rating?
Old May 8, 2009 | 03:10 PM
jbewley's Avatar
jbewley
I want to put resistor on the rear fog connector, but can not find the ohm or watts rating for the bulb.
It is not in the manual and neither parts nor service at the dealership can not tell me. Does nayone here know what it is for a 2009 MC?
I did a search here and came close, but that only counts in horse shoes and hand grenades.
Thanks,
Jim
Old May 8, 2009 | 03:23 PM
Oxybluecoop's Avatar
Oxybluecoop
The MINI electrical diagrams might help, download this: http://www.mcaw.info/wds/MINITIS.zip
You'll need Java and Adobe SVG viewer on your computer.
Old May 8, 2009 | 04:11 PM
rkw's Avatar
rkw
The Owner's Manual says the rear fog bulb is "21 watt bulb, P 21 W".
Old May 8, 2009 | 04:22 PM
jbewley's Avatar
jbewley
Where in the owners manual did you find that? I read it cover to cover yesterday and did not see it.
Thanks,
Jim
Old May 8, 2009 | 04:24 PM
jbewley's Avatar
jbewley
Thanks Oxyblue. I'm sure this will come in handy as soon as I figure out how to open it so I can read it.
Jim
Old May 8, 2009 | 04:50 PM
rkw's Avatar
rkw
Page 117 in the pdf manual:
https://ol.miniusa.com/auth/ViewMINI...NI_Hardtop.pdf
Old May 8, 2009 | 05:25 PM
jbewley's Avatar
jbewley
Thank you rkw. I followed your advice and sent an e-mail to both minispeed and newministuff (both UK based) asking if they had a fix or if they had seen this problem, but have not gotten a responce yet.
I will rear the PDF.
Thanks again. This is a great site.
Jim
Old May 8, 2009 | 05:41 PM
rkw's Avatar
rkw
If you're trying to avoid a bulb out warning, look at the resistor values that LED vendors use. Superlumination uses about 20 ohms for a 25 watt bulb and it will probably work, or at least a good value to start with.
Old May 8, 2009 | 07:11 PM
jbewley's Avatar
jbewley
Thnks again rkw. This is a bit out of my area so I will go with your recomendation and see hosw it works.
Jim
Dec 23, 2015 10:36 AM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
