Suspension Question on sport suspension on the factory JCW
Old Apr 22, 2009 | 12:31 PM
M3This's Avatar
M3This
Ok guys I have a 2009 Factory JCW car ... as one of the options taht came on my car was the $500 sports suspension. On the MiniUSA.com is says larger sway bars, but I have also read in here that it has different springs and such. Is this true?
Also can anyone tell me what the spring rates are for the sport suspension if they are different then stock.
Please note Im not talking about the JCW Sport Suspension (Red Springs) as I DO NOT have that.
Thanks!
Old Apr 22, 2009 | 01:38 PM
M3This's Avatar
M3This
found some answers:
so yes the JCW and Cooper-s come with the exact same suspension
The sport suspension (on all models) is different sway bars by 1mm and different springs ... however I cant find the spring rates on the sport suspension.
Anyone know the spring rates to the sport suspension (non-JCW)
Old Apr 22, 2009 | 07:38 PM
TheBigNewt's Avatar
TheBigNewt
The Reader's Digest version is no, nobody can show the springs are any different than the stock springs. Somebody noted a different part number, but not any difference in the springs themselves. The swaybars of course are verified thicker 1mm front/rear. FYI aftermarket swaybars start at 2mm thinker than stock, and are only made for the rear because thicker rears reduce understeer (thicker fronts increase understeer) and the car wants to understeer.
Old Feb 1, 2012 | 08:19 AM
minimini482's Avatar
minimini482
was anyone able to find the spring rates on the sport suspension (non-JCW)?
why is this info so hard to find?
I'm just trying to determine which rear sway bar size to order. I have a 2010 factory JCW with the optional ($500) sports suspension.
Old Feb 24, 2012 | 05:35 PM
TerminalVelocity's Avatar
TerminalVelocity
What size swaybar does the sport suspension (your current one) have? I keep reading that an aftermarket 19mm swaybar is the way to go if your looking for improvements on a daily driver that sees spirited driving as well as the occasional track.
Old Feb 25, 2012 | 05:25 AM
richardsperry's Avatar
richardsperry
You can't find the info, because Mini isn't saying, and nobody has made the effort to actually measure the spring rates, and publish the results.
It's not that hard, it's just a load cell and a dial indicator.
Old Mar 9, 2012 | 08:10 PM
smoke05S's Avatar
smoke05S
Hmm I have a load cell and some sport springs laying around and a press large enough to crush the Terminator. If I can figure out how to hold it without it shooting out across the room maybe I'll try it.
On my 2009 JCW with sport suspension option my dampers also say "sport" on them. I thought just the rear sway bar was 18mm and the front was stock thickness. The sport suspension is better than the stock for mildly spirited driving but it pitches fore and aft under heavy acceleration and braking and ricochets off every road irregularity. I ended up with a 22mm rear sway bar ( could not pass up the deal ) and NM springs. Pitching and the ricochet effect are gone and the car can be tossed around now with no worries.
Old Mar 9, 2012 | 09:54 PM
hsautocrosser's Avatar
hsautocrosser
The exact springs used depend on the weight of your car which varies with different installed options.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Longjas
Aug 24, 2015 06:06 AM
ASRman
Aug 13, 2015 09:33 AM
xpunisherx
Aug 10, 2015 10:50 PM
