R50/53 Power steering failure
Old Apr 7, 2009 | 09:47 PM
ninjamini's Avatar
ninjamini
Every once in a while the power steering goes out for a minute or two then comes back on. Any ideas?
Old Apr 8, 2009 | 01:52 AM
-=Mike=-'s Avatar
-=Mike=-
I'd say your PS pump is failing. I hope the car is still under warranty. If not look for a reliable repair shop in your area, as nearly all of them use the same repair manual to base their charges on.
When mine failed I discovered it when I tried to make a right turn. Good thing nobody was on the other side of the street, or I probably would have crashed into them.
Old Apr 8, 2009 | 03:55 AM
Bajanmini's Avatar
Bajanmini
Firstly your PS fan could be the prob(start car turn on A/C PS fan should kick in with radiator fan) ,if the pump is dead BBA-reman.com is a source much cheaper than dealer replacement but you have to remove it and send it in for repair.
Old Apr 8, 2009 | 05:58 AM
thecigarman's Avatar
thecigarman
Do a search, there are many threads about PS system and failure.
Old Apr 8, 2009 | 06:30 AM
buzzsaw's Avatar
buzzsaw
How's the fluid level?
Old Apr 8, 2009 | 07:05 AM
Bajanmini's Avatar
Bajanmini
Good call,if adding fluid make shure it's Pentoshin CH11S mormal PS fluid is not recomended
Old Apr 8, 2009 | 08:39 AM
WJHMH's Avatar
WJHMH
Excellent info on this thread.
Manny_cooper
Sep 10, 2015 11:09 AM
bansasn
15
Sep 4, 2015 01:24 PM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
minipopkart
Aug 13, 2015 05:22 AM
